Identify a part
Old Sep 12, 2012 | 09:02 AM
Noah's Avatar
Default Identify a part
Found this laying in the 'Vee' of my 5.3L V12. Not sure if it's part of an injector or what? It was laying in the area under the a/c compressor after I moved the compressor to do some maintenance. Thoughts?
Old Sep 12, 2012 | 09:04 AM
Sean B's Avatar
looks like the inner part of a schrader valve, may have pinged off while on a tire service?
Old Sep 12, 2012 | 09:32 AM
Noah's Avatar
Thanks, I think you're right. Strange location to find it. Also found part of a zip tie further back in the area. It certainly justifies my decision to clean it up the vee.
Old Sep 12, 2012 | 10:35 AM
Doug's Avatar
A/C charging ports use Schrader valves
Old Sep 12, 2012 | 11:49 AM
Roger95's Avatar
Schrader valve most likely from past A/C work.
Old Sep 13, 2012 | 08:18 PM
Greg Edge's Avatar
The thing on the left is a dime. The thing on the right is a Schrader valve that someone dropped when repairing the A/C.
Old Sep 13, 2012 | 08:49 PM
Darel's Avatar
If you found a dime lying in your vee, you are officially the first XJ-S owner to get money back from your car.
Old Sep 13, 2012 | 09:51 PM
Noah's Avatar
I also found a petrified peanut in the headlight bay when swapping out a light so I guess I came out ahead there also.
20 yrs ago I bought a pos Honda the day before leaving for spring break and found a sack of weed in the glovebox. We disposed of it accordingly.
aholbro1
Dec 29, 2024 06:46 PM
JarodL
Mar 7, 2024 01:39 AM
trosty
26
Dec 18, 2022 06:40 PM
Scott B
Oct 24, 2015 01:29 PM
TC Johnson
Sep 2, 2015 09:30 AM
