installing front springs
Old Feb 17, 2012 | 07:56 PM
Peter Nine Lives's Avatar
Default installing front springs
Hi all need some help! Removing the front springs from the xjs is the easy part . Any tricks or suggestions on re installing them?
Old Feb 17, 2012 | 08:42 PM
b1mcp's Avatar
I'm sure you know that there is a special Jaguar tool to do this and that's the recommended and safest way.
But I don't have the tool, so I do it with threaded rod. I've attached a picture (or tried at least), hopefully it is self explanatory. This is an X300 spring but principle and approach is the same.
Old Feb 18, 2012 | 12:26 AM
warrjon's Avatar
3/4" threaded rod mine is about 36" long (you don't need it this long 16" is enough)
The long bit in the middle is a bit of gal water pipe cut on an angle I made the large washer to sit against the lower spring seat and the bit of pipe.
The rod goes through the center of the spring with a nut and washer on top and I use vice grips to stop the rod turning. Cost me about $15 from Bunnings (like Home Depot).
edit just saw you in Ozzz, where abouts are you?
Old Feb 18, 2012 | 03:58 AM
Thank you so much for the help guys they're both great ideas. I will look into it in the following week ... and warrjo n I'm from south Australia
Old Feb 18, 2012 | 04:30 AM
plums's Avatar
Is that due to the curve in the spring?
Old Feb 18, 2012 | 05:54 AM
Greg in France's Avatar
When you install the spring, when it is seated on the subframe at the top, with the spring pan in place but before compression, the spring and pan are at a considerable angle to the lower wishbone, as it is hinged about a point well above the extended spring's end. This angle gradually diminshes as the spring is compressed, but is never 90°. The effect is that the inner side of the spring pan is always trying to open up the angle as it is more compressed than the outer side, so the angle cut on the centre compressor piece forces the pan into the correct position relative to the lower wishbone, as the spring is compressed. The JEC tool, which I use, has a ball-shaped piece in that location, to achieve the same effect.
Greg
Old Feb 19, 2012 | 02:51 AM
Thumbs up
ANOTHER South Aussie.
If you are SUPER NICE, I have the GENUINE Jaguar front spring instalation tool in a bag in the shed.
PM me on gyfrancis(at)adam(dot)com(dot)au, if you are interested.
The car will need to be super high, or the subframe OUT to use this tool, as it is designed for a car up on a hoist. As said, that centre bolt is looooooong, and I am NOT cutting it for anyone hahaha.
Old Feb 19, 2012 | 03:30 AM
warrjon's Avatar
Hey Grant you want to edit your post and remove the links use the following or you could be inundated with SPAM.
Old Feb 20, 2012 | 02:52 AM
Thanks Warren, done.
I keep forgetting the demons out there, old age I suppose.
Old Feb 20, 2012 | 03:07 AM
plums's Avatar
Further edited to remove the underlying html tag which still contained the real email address.
bamforp
Aug 14, 2024 05:36 PM
Dz1rfj
Jul 17, 2018 10:29 AM
Dz1rfj
Sep 16, 2015 03:44 PM
Tar
Sep 6, 2015 11:24 AM
mhamilton
US Lower Atlantic
Sep 4, 2015 05:00 PM
