jag xjs v12 oil coming through intake
Old May 19, 2013 | 02:11 PM
jag-xjs-guy's Avatar
Angry jag xjs v12 oil coming through intake
hi
i have just bought a jag xjs v12 1987
after driving it home i opened the bonnet and found there to be oil coming from the left air filter housing so i cleaned it up and went for a drive i got home and checked to see if there was any oil there and there was.
what could be causing this?
thanks
Old May 19, 2013 | 03:02 PM
Steve M's Avatar
I think that you will have to take the air cleaner off to investigate further; I would suspect a blown manifold gasket.
Old May 20, 2013 | 03:41 AM
Greg in France's Avatar
Originally Posted by jag-xjs-guy
hi
thanks
The crankcase ventilation system goes into the LHS air cleaner. take off the cover, remove the air filter and you will see the system entry holes. One pipe comes in from the front of the engine, via a large roundish rubber connector on the front LHS of the engine, the other comes from the LHS manifold top and includes a sprung a sprung valve. Remove all these and clean them up, including the mesh filled canister under the rubber thing, and then see what happens afterwards.
Greg
Old May 20, 2013 | 04:27 AM
OK, first thing, you are NEW, so welcome.
greg has nailed it. That vent system is a bugga at best, and makes a real mess of filter elements and where it all drips to.
Mostly caused by crankcase compression, and on a V12 that is due to toooooo quiet a driving style.
This engine just loves to rev, and since you have just purchased it, you are naturally cautious.
Do what Greg said, most important.
Give it an oil change, using a good quality oil, then do all the sensible checks, and go for a "good squirt", as we say.
My V12's get all hissy with city driving and a good 1000km interstate blast on a regular basis, does absolute wonders to them.
BrentGardner
29
Dec 16, 2024 12:13 AM
FabCat
Canada
Aug 20, 2023 10:11 AM
1100me
Aug 27, 2020 11:37 PM
rmbtl2
Aug 26, 2015 08:52 AM
