Leakkk help!
Old Mar 19, 2015 | 01:29 AM
differentchances36's Avatar
Default Leakkk help!
when i drive my 1983 XJS with a chevy 350 and then park. i notice it leaks pinkish fluid from which i believe is differential fluid. its coming from the boot .. any suggestions>?
Old Mar 19, 2015 | 03:29 AM
I've moved your question from the Jaguar Original Equipment Manufacturers (OEM) thread in General Tech Help to XJS forum.
Members here with the same model will be able to help.
Old Mar 19, 2015 | 07:05 AM
texasscot's Avatar
If its a convertible,
its probably hydraulic fluid from the hood mechanism. Is it on the left hand side?
Old Mar 26, 2015 | 01:57 PM
It is on the passenger side. right boot.
Old Mar 26, 2015 | 06:11 PM
ptjs1's Avatar
That sounds confusing.
Pink fluid would tend to indicate an ATF-type fluid as fitted in Auto gearboxes, PAS systems or possibly a convertible pump motor. But not diff fluid.
But I guess if you've got a 1983 car, then you've got a Coupe, not a convertible. Unless it's been converted as an aftermarket conversion?
Are you sure it's coming from back right corner? Have you got a converted convertible?
Paul
Paul
Old Mar 26, 2015 | 08:52 PM
Bc xj's Avatar
Here is the photo Differentchances sent me.
Old Mar 26, 2015 | 09:09 PM
texasscot's Avatar
I've never been good at left and right. When I said left I meant right as that's where the convertible reservoir is. However, being British I also assumed boot was trunk. Then I see the photo and think "that's the front suspension and steering rack" and the boot is the bellows piece - the boot!
Looks like its power steering fluid? Best i can do!
Old Mar 27, 2015 | 03:02 AM
Greg in France's Avatar
That is power steering fluid from a leak from the steering rack, which needs a rebuilt one installing in its place.
Greg
Old Mar 27, 2015 | 09:15 AM
sidescrollin's Avatar
well he said "the boot", so noone blames you. I was actually coming back to this thread to make a point of letting him know that little progress has been made because no one has any idea what he is talking about, but are being too polite to be more direct about it.
Thats like saying "the door hinge" and referring to the gas door.
Glad that pic was posted though, I had honestly no idea what he was on about, it made zero sense lol.
Definitely need to rebuild the rack or buy a rebuilt one, it is toast!
