low coolant light flashing
Old Feb 9, 2013 | 10:08 PM
northern's Avatar
Default low coolant light flashing
after installing a new radiator, water pump and all new hoses on my 82 xjs he the low coolant light flashes after i start it up. havent drove it yet but it is full of coolant, where is this sensor located? i dont see any on the radiator.
Old Feb 9, 2013 | 10:30 PM
Doug's Avatar
Are you *sure* it isn't in the radiator? Take another peek. RH radiator tank, about 1/3 way down from the top, perhaps?
If not there then perhaps the metal header tank mounted on the left side of the engine bay?
Old Feb 10, 2013 | 02:37 AM
Greg in France's Avatar
The low coolant light sensor on the HE is on the header tank on the US drivers side inner wing, just aft of the radiator and headlight nacelle. You will see the wire going to the sensor. Is this tank topped up?
Greg
Old Feb 10, 2013 | 02:56 AM
Graham Royls's Avatar
Had same problem Discovered "lock " in heater . Cycled heater/ AC 3 times .
Problem fixed
Old Feb 10, 2013 | 01:56 PM
northern's Avatar
Yes tank is full. radiator full and air blead out.
Old Feb 11, 2013 | 12:16 AM
northern's Avatar
Well pulled it out of the garage today, parked it and put the cover on. Its going to be a month or so before I drive it anyway (Alaska) but looked on the coolant tank and radiator again for a sensor wire. don't see anything that looks like one. cycled the heater on and off, cold-hot, the ac has not been recharged yet so the compressor don't kick in but light still flashing away. hmmm
Old Feb 11, 2013 | 01:18 AM
Exact model and year please?
Greg
Old Feb 11, 2013 | 05:43 AM
Steve M's Avatar
Did you open the bleed valve at the top left of the radiator? You could still have an air lock in there. Open both caps and the bleed valve and I bet that the level drops.
Old Feb 11, 2013 | 12:23 PM
northern's Avatar
1982 5.3 HE coupe.
Old Feb 12, 2013 | 01:27 AM
1982 5.3 HE coupe.
According to the Great Palm's book, sub-section on Cooland Level Sensor, the HEs in 1982 had the CLS on the front of the radiator, RHS, and it is very hard to see unless the hood is off! (Maybe removing the rad top panel would do it?). The sensor was moved to the header tank on the inner wing by 1985 models.
He suggests moving it to the header and says how to so so.
Greg
JarodL
Mar 7, 2024 01:39 AM
afterburner1
Dec 16, 2015 12:12 AM
redrover41
23
Sep 25, 2015 01:33 PM
KarimPA
Sep 3, 2015 07:32 PM
OkieTim
Sep 2, 2015 12:48 PM
