lower control arm bolt stuck
Old Jul 25, 2013 | 05:45 PM
calvindoesntknow's Avatar
Default lower control arm bolt stuck
the Lower control arm bolt is stuck
I went to remove the bolt from the big end. which is a nut that's punched to stay on.
any ideas to get it out? tried everything I could to hammer it and other suggestions?
Old Jul 25, 2013 | 08:14 PM
FastKat's Avatar
I think I had to tap mine out with a hammer. It wasn't hard, but I never would have got it out by hand.
You have the bolt off, right? And the spring off?
Old Jul 25, 2013 | 08:18 PM
yes I have both off, I might need to use a hydraulic press the way this is going so far
Old Jul 25, 2013 | 08:48 PM
Calvin,
Many, many years ago, we had a S3 that would not bash out.
Much language later we hired one of those electric "jack hammer" chisel things, with a flat faced tool in its snout, and got into it. It still took some serious HARD work, but it did come out.
The daughters S2, NO WAY would either of them come out, so we simply swapped cradles from a PerHE XJ-S.
Probably not the suggestions you really want to hear, but that's my experience with the tough ones. All the others have simply tapped out easily.
Old Jul 25, 2013 | 09:25 PM
motorcarman's Avatar
If the suspension 'took-a-hit' and the fulcrum bolt is 'S' shaped, then the best way is to use a 'cut-off' wheel/metal saw and sever the bolt at the bushes, pull the lower arm and remove the pieces.
Rusted bolts might come out easier if cut and they are shorter. You can determine where the corrosion is and isolate the section for heat or penetrating oil.
The oil pan on the V12 will get in the way of the bolt removal so the subframe will need to be lowered or the engine raised. The 3.6 or 4.0 will be easier.
(been-there, done-that)
You might help us (and YOU) if you put some details on WHAT CAR YOU HAVE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
bob gauff
Old Jul 25, 2013 | 11:17 PM
icsamerica's Avatar
Default sledge hamma
Somestime the busing rusts to the fulcrum. I've had luck persuading it out with the bushing using a sledge hammer and 1/2 inch impact extension. You will likely need a new fulcrum pin anyway if its rusted.
Old Jul 26, 2013 | 01:36 AM
Greg in France's Avatar
This is what I did with mine which was utterly stuck:
  1. Remove cradle
  2. Put hacksaw blade into the electric saw
  3. There is JUST roome to cut between the inside of the arm and the cradle
  4. Cut both sides
  5. Arm falls off, burn out old bush from arm holes
  6. Take huge drift and lump hammer and belt out piece of arm in cradle
  7. Derust and crease up cradle before refitting new pin
The problem with whacking out the pin before cutting it is that the rubber bush in the arm hole damps out most of the "whack" so hitting it does not do much. At least this way at the cost of a few blades (at least one per cut, maybe two) there is a befined time and then the job is done.
Greg
Old Jul 26, 2013 | 07:01 PM
the car is an 87 v12 and the cage is currently out of the car, so I'll be doing the work on the bench
Old Jul 28, 2013 | 08:02 AM
Katoh's Avatar
Just to make sure we are talking about the same part, you are trying to remove the lower wishbone fulcrum bolt?
Ok I don't have to much experience with jags but have played around with many cars and trailers mainly marine, and they just they rust!
You have the cradle removed from the car that's fantastic and a great start.
Find a thin cutting blade for a grinder, even a little 4" will do the job and cut the back of the bolt clean off, not the threaded side. You will be changing the bush's of course well I would hope so, even if you cut into the bush, all good.
just make sure you cut through the the shaft of the bolt and leave no bits larger than the shat. after your done then refit the castle bolt to the threaded side with a washer bigger than the bush. Tighten the darn thing up and after its tight, hit the darn thing with a rattle gun! The first thing it will make it do is spin inside after it turns a bit it will come loose. once it turns freely rift it out from the cut side.
Nothing seems to work better on rusted bolts and shafts than a rattle gun, butt you must cut the other side of first. Be careful not to damage the wishbone while cutting. Some Inox or WD40 or penetrating oil sprayed onto the bolt works wonders as well
Hope this helps.
Good Luck
Old Jul 29, 2013 | 06:47 PM
where can I find these bolts? I have one sight in.England found but are there any stateside?
Old Jul 29, 2013 | 06:58 PM
FastKat's Avatar
Is this it?
Jaguar XJ6 XJ12 Front Lower Control Arm Bolt 90 97 | eBay
Old Jul 30, 2013 | 12:56 AM
Katoh's Avatar
Here you go new in the US.
Fulcrum Pin - C30722 or C30722
Do a search part no. C30722
Good Luck
Old Jul 31, 2013 | 07:53 AM
86jag's Avatar
I ended up using a hacksaw and cutting off the bushings which allowed me to spray some penetrating oil into the bolt hole. I then worked the bolt by trying to tighten and loosen it which then "broke" it loose. I then sludge hammered the fulcrum pin out. I purchased two new ones which were zinc coated from sng Barrett for about $20-$30 each and put lots of anti sneeze compond when I reassembled it. I originally tried my best to save them but bashing it with the sludge hammer really screwed it up.
Old Jul 31, 2013 | 05:21 PM
well i sawzalled the bolt off so the suspension dropped off, and then i slammed the bolt a bunch of times with a sledge hammer, and it didnt come out, so i think i might need a new front subframe because i cant get this bolt out, does anyone have one?
Old Jul 31, 2013 | 08:43 PM
icsamerica's Avatar
Default torch?
Heat is your friend. Do you have a Oxy/Actl kit?
Old Jul 31, 2013 | 08:46 PM
no I do not, how would I go above using heat?
Old Jul 31, 2013 | 09:20 PM
Big_Walleye's Avatar
I would take it to a machine shop and get them to press the bolt out.
Old Jul 31, 2013 | 09:27 PM
icsamerica's Avatar
Default try map
You can try a map gas tourch from your local big box store. Map gas burns hotter than propane. Heat up the affected parts and let cool it quick with water. That should crack any rust that may be holding it... do this about three times. Then heat it up again and bang it out. I hope this frame is in some sort of large vice or some thin else firm. If not put it back on the car.
You may also find success just heating up the bushing in a ventalated area they should melt and then see if the rod comes out. Make sure you have a fire extingisher at the ready. The rubber will burn and drip.
Old Jul 31, 2013 | 09:32 PM
icsamerica's Avatar
Default nother idea...no fire necessary
Cut the fulcum pin flush to the subframe and use a hole saw larger then the pin but smaller than the subframe to chew away the rubber bushing. Then the pin should come out.
Old Jul 31, 2013 | 10:34 PM
SUCCESS AT LAST! the bolt is out, the problem was itwas bent due to the car having been aairborne at some point in its life. I resorted to a larger sledge hammer and got the bolt out. the other came out wirhout any problem.
