Lower Control Arm Shaft Bolt Thread
Old Aug 11, 2023 | 08:20 PM
Jagsandmgs's Avatar
Default Lower Control Arm Shaft Bolt Thread
Does anyone happen to know the thread/size of the lower control arm bolt nut? Day dreaming about a non-destructive removal method and need to cost out a tap…
Old Aug 11, 2023 | 08:24 PM
Jagsandmgs's Avatar
Gave up googling too fast…. Appears to be 9/16 UNF
Old Aug 12, 2023 | 01:34 AM
Greg in France's Avatar
Front or rear suspension?
Old Aug 12, 2023 | 09:37 PM
Jagsandmgs's Avatar
Front!
planning to make a sacrificial extension and a correct angle pipe thing to press the lower fulcrum out.
Old Aug 13, 2023 | 01:43 AM
I had to use a sawzall with a metal cutting blade, which wwill just go between the cage and the wishbone eye, to cut my fulcrum pin each side of the cage, and thus release the wishbone. Then burn the old bush out of the wishbone eyes, and then I could bash out the pin, eventually, from the cage. I hope you do not have to go to these lengths!
Use loads of nickel anti-seize on the new pin where it gos through the cage.
topanga
Jun 1, 2022 03:11 PM
Playerpetegunn
Nov 28, 2020 03:55 AM
prodigy215
Jun 10, 2020 02:31 PM
calvindoesntknow
Aug 2, 2013 06:22 PM
Noxparadise
Nov 24, 2012 02:49 PM
