New Owner First Parts order List
Old Apr 13, 2020 | 12:47 PM
Pscottorn's Avatar
Default New Owner First Parts order List
Good evening
I plan to make my first parts order for my 1994 6.0 convertible in the next 48 hours. Given that my order(s) will require international shipping due to my location in Abu Dhabi I would prefer not to miss anything silly off the order. Would other forum members please be so kind to take a look at the below parts list that I am planning to purchase and let me know if you think I have missed anything. It is likely to be the small things that get forgotten but you never know....
Cooling hose kit
Fan automatic viscous clutch
Thermostats
AC condenser mounting bushes
Tie rod end boots
Front sub frame mounts (small cracks)
Radiator caps x2
Valve cover gaskets x2
Rear suspension bushings
Engine oil pan gasket
Spark plugs
Spark plug leads
Distributor cap
Rotor
Plastic throttle bushings
Metal Expansion tank
Intake manifold gaskets-2pcs left and right
Water pump
oil filter
air filters
Old Apr 13, 2020 | 02:30 PM
VancouverXJ6's Avatar
Ah, a month's wages and then some!
Quite a list, and some things to pay special attention to - you can avoid the thermostat fiasco among other things, I'd suggest:
https://www.superflex.co.uk/products.php?cat=211 for bushings.
K&N make a good reusablwle high flow filter I've had luck with their latest batch. Amazon, rockauto, etc good places to look.
Genuine heavy OEM rad caps come from JaguarClassicParts.com most listed on other sites don't actually work.
Old Apr 13, 2020 | 09:12 PM
Jagboi64's Avatar
Be aware that the OEM thermostats are actually not correct. The foot that blocks off the bypass port doesn't extend far enough to actually block it off, so approximately half of the water never goes through the radiator. In your climate the cooling system needs to be running at 100% capacity. Instead use Gates 33188S, but you will need to drill a small (~5/64") hole in the top flange as an air bleed. Installing these thermostats made a noticeable difference to the cooling capacity of my car.
If you're doing as much servicing as that, you might want to add a transmission filter and pan gasket, unless those are available locally. The transmission is a GM 4L80E, used in plenty of GMC/Chevrolet products.
Old Apr 13, 2020 | 09:51 PM
A good trans flush is worth it yes, I believe Trico sells the EXACT thermostat needed but I don't recall the part #. Depends on where your located.
Old Apr 13, 2020 | 10:25 PM
Jagboi64's Avatar
Originally Posted by VancouverXJ6
I believe Trico sells the EXACT thermostat needed but I don't recall the part #. .
I think it was only sold in Australia/NZ and is now discontinued.
Old Apr 14, 2020 | 02:52 AM
Dukejag's Avatar
Jagbro... being in NZ do you have a part number?
This job is on my list!!
Old Apr 14, 2020 | 10:09 AM
Jagboi64's Avatar
Dayco DT18A. See Grant's post here: https://www.jaguarforums.com/forum/x...2/#post1302110
Old Apr 14, 2020 | 12:04 PM
leo_denmark's Avatar
I would suppose a ‘94 to have electric fans. That means you can delete the viscous clutch from your list...
Old Apr 14, 2020 | 12:17 PM
Jagboi64's Avatar
Not the V12, it kept the mechanical plus electric.
tsimms7
May 17, 2015 09:25 PM
desertchimera
Jan 6, 2014 09:28 PM
Wahooesprit
Oct 28, 2012 07:31 PM
jbrumme
Sep 17, 2012 03:27 PM
SilverSType
Feb 4, 2010 04:17 PM
