Noise from front right... sounds like woodpecker under throttle.
Old Apr 22, 2021 | 07:14 PM
944xjs's Avatar
Default Noise from front right... sounds like woodpecker under throttle.
I redid the trans-mount last summer to cure what is a knocking sound on throttle. The noise seemed to dim a bit but is still there.m, especially it seems if turning onto a road while accelerating from a stop. Are there any other pieces that could make a nice hard woodpecker knock? Definitely throttle/engine/vibration related. It really seems further up front right than underneath the center of the car where one would think the trans mount knocking would be. Any help would help.
Old Apr 22, 2021 | 08:08 PM
Vee's Avatar
Vee
I had an issue like that. Sound occurred most expectedly when making left hand turns from a stoplight.
Turned out one of the engine mounts were bad. Appeared fine, but had delaminates so when the engine torqued itself it would just lose contact with the frame to cause some chatter.
Old Apr 22, 2021 | 08:23 PM
944xjs's Avatar
thats exactly like mine... left from a light is the loudest! I looked at the right motor mount from a distance just to make sure it was at least there. Well, how big of a pain is this going to be?
Old Apr 23, 2021 | 12:33 PM
ChrisHarley2008's Avatar
I had this exact situation and noise. After rebuilding the rear cage, it disappeared. This included springs, shocks, diff fluid change and cage mounts.
Old Apr 23, 2021 | 12:38 PM
944xjs's Avatar
I ordered a set of engine mounts. I’ve always had a feeling that that was probably the issue but now we’re gonna find out
Old Apr 23, 2021 | 08:02 PM
Vee's Avatar
Vee
It’s not terribly difficult.
I changed both too, but the drivers side was the one that was delaminated. Looked fine visually.
You’ll simply need to jack up the engine from below. The bolts are not easy, but not difficult to get to. There are nuts on the underside of the bolts that you won’t see. You can get to them by feel though. Once loose, you can jack the engine up enough to replace the mount.
MHC7521AA and MHC7522, right?
Old Apr 23, 2021 | 10:42 PM
944xjs's Avatar
yeah, that’s easy enough. Well, until you get in there and round that nut off. Ha
i went with the cheapo uro. 👍🏼
Old Apr 23, 2021 | 11:17 PM
VancouverXJ6's Avatar
You can test your eng mounts by popping the hood, 1st gear brake ON and rev the engine...it should not lift off at all, infact you should be able to balance a large coin on a running engine or a fine wine glass with ease.
Old Apr 23, 2021 | 11:24 PM
944xjs's Avatar
i did that today, actually. Engine almost spun 😆. No but it did lift fairly substantially.
Old Apr 24, 2021 | 03:00 AM
Mounts are done then, my car had this once and there is a hood dent to prove it haha, also from personal experience avoid URÖ mounts. Junk.
Old Apr 25, 2021 | 08:56 AM
Vee's Avatar
Vee
I have used URO before....not nearly as bad as MTC. That was bad.
OEM rubber is substantially better than all aftermarket. If it’s easy to get to, like these, it’s not the end of the world to save money and use URO parts. If they fail again, you won’t be paying a shop for their time, so it’s a low risk situation.
Old Apr 25, 2021 | 10:22 AM
944xjs's Avatar
Yeah I’m not terribly worried about uro parts. I’ve used many in the past. I’m sure the oem is better but for the savings I can get a new speedometer transducer.
vincent661983
Oct 29, 2018 07:58 PM
Gordo1968
Jun 16, 2018 09:43 AM
sverroc
Jun 20, 2012 07:12 AM
whm54
Nov 5, 2011 09:47 AM
Prowler
May 6, 2010 02:06 PM
