Noise of interior fan/blower
Old Sep 18, 2022 | 03:33 PM
Jatto's Avatar
Default Noise of interior fan/blower
Hi,
I own my XJ-S from 1993 for two weeks. With the bad and cold weather in the Netherlands I’am using the climate control of the Jag.
but….in the LOW position the noise of the interior fan is pretty much. This compared to a modern car which start with a low speed (and low noise).
Is it normal that the fan makes pretty much noise even in LOW?
Or is there something wrong with the electronics to control the fan speed? In MID and HIGH the fan is blowing more with more noise….
Old Sep 18, 2022 | 06:21 PM
motorcarman's Avatar
Which fan right or left?
Might need to drop the fan(s) to see if some foreign object is lodged in the blades of the blower?
Maybe a bushing is worn?
Old Sep 19, 2022 | 10:46 AM
equiprx's Avatar
There is a long list of things that can all be solved by removing the fans and servicing the motor bearings.
Getting the fans out from under the dash is the only hard part, the rest is easy.
Old Sep 19, 2022 | 10:54 AM
ptjs1's Avatar
It could be a failure of the Darlington transistor which can cause one of the fans to run at the higher speed when set on Low.
Good luck
Paul
Old Sep 19, 2022 | 10:59 AM
Jatto's Avatar
Thnx! I don’t know if it’s the right or left fan. We should open the dash then to look at the fans and the Darlington transistor.
indi4ever
XE ( X760 )
Jun 10, 2022 12:50 PM
Parzival
Mar 13, 2015 11:15 AM
randyb
Feb 3, 2015 03:21 AM
James Lewis
27
Aug 22, 2013 06:06 PM
avt007
Aug 6, 2013 10:54 PM
