Noisy fuel pump - ‘94 4.0
Old Jul 11, 2023 | 10:38 PM
XJDanny's Avatar
Default Noisy fuel pump - ‘94 4.0
Greetings from Seattle, Washington.
The fuel pump in my ‘94 4.0 is pretty noisy. I can easily hear it inside the cabin when the car is idling. When I’m driving on the road, I don’t notice it. Is this normal? Should I be able to hear it inside the cabin? The last thing I want to do is have to replace a fuel pump inside the gas tank.
Old Jul 12, 2023 | 12:13 AM
orangeblossom's Avatar
Hi Danny
Yes that's right!
The last thing you ever want to do is replace an In-Tank Fuel Pump on an XJS as it's the 'Job from Hell'
Though having said that, Fuel Pumps don't last forever, so someones got to do it, or else pay someone Megabucks to do that job for you! $2000-$5000
Mostly Labor (it could take a 'Shop' a Couple of Days!)
Old Jul 12, 2023 | 07:38 AM
XJDanny's Avatar
I know it’s not easy to replace, but I don’t want to do it just because I can hear it running (if it’s normal). The fuel pump in my XJ6 is also noisy and it’s been noisy since I replaced it a few years ago. I can hear that one from inside the cabin, too. I replaced that fuel pump proactively and it’s not any quieter than the old one was.
I just want to know if others can also hear their fuel pumps from inside the cabin. Is it normal?
Old Jul 12, 2023 | 01:54 PM
Vee's Avatar
Vee
I have a slightly newer car, and I never hear the fuel pump in the car.
There is a way to replace it without removing the tank. Apparently you should be able to shimmy that tank out just far enough without having to pull it out entirely. It apparently can be done.
I think it's a job coming your way very soon.
Old Jul 12, 2023 | 02:40 PM
ptjs1's Avatar
Danny,
I've never heard my fuel pump from inside the car.
Possibly a naive question as you obviously have Jaguar experience, but it's definitely the fuel pump you can hear and not the brake accumulator pump in the engine bay?
There's a few videos and pics around showing how the pump can be extracted apparently relatively easy, wiggling the right hand side of the tank to the back of the car.
Paul
Old Jul 13, 2023 | 03:42 AM
Greg in France's Avatar
Have you changed the fuel filter recently?
Old Jul 13, 2023 | 07:49 AM
XJDanny's Avatar
I’m thinking the same thing about the fuel filter. I’ve only owned the car four months and I haven’t replaced it. I just ordered a new fuel filter last night and I’ll put it in next week. I’m hoping that’ll quiet down the pump. If it does, I’ll post that here. Fingers crossed!
Thank you!
Old Jul 13, 2023 | 07:55 AM
XJDanny's Avatar
Yes, it’s definitely the fuel pump. The sound is coming from the rear. It actually sounds exactly like my fuel pump in my Series III XJ6, which is new. Well, it was new a few years ago and was/is as noisy as the fuel pump I replaced.
Thank you for suggesting the videos on replacing the fuel pump. That’s good to know they’re online. I’ve read the tank can be accessed by wiggling it back a little rather than removing it. The first thing I’ll do is replace the fuel filter and see if that quiets down the pump. I’m hoping…
Old Jul 18, 2023 | 07:23 PM
XJDanny's Avatar
I replaced the fuel filter but the pump is still noisy
Old Jul 18, 2023 | 08:59 PM
Vee's Avatar
Vee
Start reading up on fuel pump replacement without removing the fuel tank! It’s still a beast of a job, but doable.
you’ll also need some fuel resistant hoses because the ones in your tank will be gone. Not sure what sizes, or the length, but they are short.
Old Jul 19, 2023 | 11:02 PM
XJDanny's Avatar
Does anyone have a recommendation on what kind of fuel pump I should get? Kirby’s book says Walbro is good. Is there a certain kind of Walbro? Also, what kind and size fuel resistant hoses should I get for inside the tank?
Thank you for any advice!
Old Jul 20, 2023 | 10:17 AM
Vee's Avatar
Vee
I believe the best hoses you can get are the Gates Barricade hoses. Somewhere there will be a post indicating what kind of size, and the length needed...I hope.
These hoses are priced by the inch, so they are not cheap.
As far as fuel pumps go, I think any name brand would be the wise decision. Walbro makes pumps for other brands as well. Denso is usually pretty reliable. Delphi, AC Delco would be good too.
I would basically buy one of the more expensive pumps here. You don't want to be cheap here.
Old Jul 20, 2023 | 09:20 PM
XJDanny's Avatar
Thank you, Vee. I appreciate the advice!
zray
Feb 26, 2025 01:43 PM
plums
General Tech Help
Jan 17, 2016 02:28 AM
Paulc732
May 27, 2015 11:32 AM
ant17
Sep 15, 2011 12:49 AM
gunnerman
XJ40 ( XJ81 )
Jun 24, 2010 08:55 AM
