Ohms for fuel sending unit
Old Jan 3, 2012 | 10:47 PM
matjohns's Avatar
Default Ohms for fuel sending unit
Need to double check I have the right numbers. I read that our XJS' (I have an '82) read 33 ohms off the unit for a full tank and 240 ohms for an empty tank. Can anyone verify if this is correct?
Thanks!
Old Jan 4, 2012 | 12:42 AM
warrjon's Avatar
Hi Mat, I'll pull mine out tomorrow and check it for you, I have looked through the ROM but can not find anything about the fuel sender.
I had my tank out - only put it back in yesterday the fuel gauge has always been dodgy, I pulled it apart and found the wipers not making contact properly - I bent them and had variable continuity from empty to full but did not take note of the values.
Old Jan 4, 2012 | 10:53 AM
Mish_Mish's Avatar
I had mine rebuilt by rewinding wires and cleaning all internals, however it gave me reading that was a bit off, so I ended up purchasing new unit on eBay, for about $60. BTW, reading you have seem right on the bottom, however on top mine was showing almost no resistance.
Old Jan 4, 2012 | 03:33 PM
warrjon's Avatar
Mine shows 19Z and 240Z. but this may not be 100% correct but the readings are better than it was before.
Old Jan 4, 2012 | 10:55 PM
matjohns's Avatar
Thanks! That's extremely helpful. I just need it to be close enough.
Appreciate it!
dsnyder586
Dec 29, 2024 07:39 PM
Dz1rfj
Jul 17, 2018 10:29 AM
skyryder
Mar 25, 2016 08:18 PM
ccfulton
Sep 20, 2015 05:15 PM
Dz1rfj
Sep 16, 2015 03:44 PM
