Over heating
Old Jun 23, 2019 | 03:18 PM
rgp's Avatar
rgp
Default Over heating
My twin fans packed up and I had over heating in traffic queses
Would it affect a/c gas ability to cool.
Old Jun 23, 2019 | 03:51 PM
Jagboi64's Avatar
Absolutely. The condenser is just a radiator and without airflow it can't shed the heat needed to condense the refrigerant. You need to be moving about 30 mph to have enough airflow to work without fans, assuming everything else is up to spec.
Old Jun 23, 2019 | 04:00 PM
rgp's Avatar
rgp
Should I change the gas. As its not as cold as it was?
Old Jun 23, 2019 | 04:32 PM
Jagboi64's Avatar
If your fans don't work, fix those and then the AC will work again, assuming everything else is ok. No AC system will work without airflow over the condenser, just the same as a car will overheat it's radiator if standing still and there is no fan or wind.
As a test, with the car standing still, spray your garden hose over the condenser to remove the heat. If you have cold air from the AC, then the rest of the system is fine, it's just inadequate airflow through the condenser.
Moshu-Jaguar
May 20, 2010 03:05 PM
badplan1
Mar 9, 2010 08:15 PM
madzander
Jul 21, 2009 01:25 PM
1985jag
May 29, 2009 09:49 AM
X2 Jag
Mar 30, 2007 12:55 AM
