Performance Chip?
Old Feb 17, 2019 | 09:45 AM
petemohr's Avatar
Default Performance Chip?
Has anyone tried one of these?
https://www.performancechiptuning.co...d2-for-jaguar/
Old Feb 17, 2019 | 12:46 PM
Flint Ironstag's Avatar
Nope. Save your money.
Old Feb 17, 2019 | 12:56 PM
Daim's Avatar
Howbisbit supposed to work? Jaguar never implemented OBD 2 into the XJS...
Old Feb 17, 2019 | 04:11 PM
petemohr's Avatar
The '96 has OBDII.
Old Feb 19, 2019 | 12:02 AM
VancouverXJ6's Avatar
If you want quick and cheap power delete or gut your CATS, and all mufflers except the rear resonators as they help with the lawn mower noise, then cut out the front face of the filter box and fit K&N filters. ECU tuning is an expensive and time consuming option where you have to send it to England so a wizard can work on it with some ancient 1980s electronic diagnostic equipment.
Old Feb 19, 2019 | 01:22 AM
Greg in France's Avatar
There is very little more power to be had on a V12 by messing around with the ECU, with the sole exception of the AJ6 Engineering stuff, which is a combined ECU and intake package of improvements supplied by an ex Jaguar engine engineer. I have this on my car and it made a very big difference to its response and high-speed performance. After that the limiting factor on an HE engine is the breathing at revs above 4,500 or so, and to improve that requires head work. The only other option is to use a pre HE engine, again with much internal work including capacity increases, in which case after substantial expense and effort, large BHP increases can be obtained.
Old Feb 19, 2019 | 01:47 AM
Unfortunately Mr. Bywater is slowing down, as he is in his 80s and there isn't anyone else to take up the task. We're going to need a drop-in solution sooner rather then later.
Old Feb 19, 2019 | 12:04 PM
How much are those Johns Cars Quarterbreed kits again? Transmissions are dirt cheap. After the exhaust and intake mods, I think 4 speed GM is the next low hanging fruit.
V12 Quarterbreed Conversion
After that, I don't know if it would even fit, but W140 class Benzes are also dirt cheap on ebay. Would make an interesting lump.
Old Feb 20, 2019 | 02:33 AM
This is a serious worry, I agree. Where do owners go from here if they have an ECU problem?
Is a drop in replacement ECU system for Lucas cars something we can find or develop at reasonable cost?
I feel what is needed is a direct replacement that can be bought and installed without the owner needing to do any tuning, rolling road work, etc etc. Is the fuelling/throttle position/vacuum load-sensing/RPM ECU map available for the OEM ECU so it can be reproduced?
I know nothing about such systems; but it would be somewhat tragic if an XJS could not be run because of lack of a suitable ECU.
woodardjl
Feb 15, 2025 03:58 PM
2004x-type
Mar 11, 2010 06:47 PM
harounq21
Jul 8, 2008 09:05 AM
gvkenny
Feb 5, 2008 02:27 AM
tkd_540
Dec 6, 2007 02:06 AM
