Pinstripes
Old Mar 29, 2018 | 08:29 AM
brinny's Avatar
Default Pinstripes
Does anyone know of a supplier for the thin style stripes down the side of the car. There’s a guy on eBay but he’s a bit expensive and sng don’t have complete sets, . Don’t want to pay a fortune for tape but would l8ke to try and keep it something like. Many thanks.
Old Mar 29, 2018 | 02:00 PM
Jagboi64's Avatar
A body shop I have used had a local signmaker make the stripes.
Old Mar 29, 2018 | 02:43 PM
George Camp's Avatar
I would try Jaguar Heritage parts or a very large dealer in the UK. They all had part numbers and at least in the US you get lucky at times. Last use I had I simply ordered a set (although you need all part numbers as there is no "set" number). Good luck!
Old Mar 29, 2018 | 04:18 PM
sidescrollin's Avatar
The thin line is part of the stripe. It is way easier to apply this way and have both lines look right, readily available.
Old Mar 31, 2018 | 10:01 AM
brinny's Avatar
Thanks lads
Old Mar 31, 2018 | 11:06 AM
MHF25's Avatar
Sidescrollin... what is the source for the pinstripe roll? Jaguar Heritage Parts no longer stocks the coachline strips.
Old Mar 31, 2018 | 11:44 AM
Jagboi64's Avatar
3M makes striping tape.
Old Apr 2, 2018 | 02:42 AM
Greg in France's Avatar
Brinny
Here they are:
https://www.ebay.co.uk/itm/Jaguar-XJ....c100005.m1851
Old Apr 2, 2018 | 02:59 AM
HARRIER69's Avatar
Halfords sell pinstripes of varying widths. I have used them for my Jaguar XE when I had it.
Old Apr 2, 2018 | 09:28 AM
brinny's Avatar
Once again thanks. I have bought a roll from an old stockist which is silver and red. Will try that and then if it’s not upto muster might get the ones on eBay. Bit dear though nearly £100 with post for a bit of tape. We will see.
Old Apr 4, 2018 | 02:00 PM
Asdrewq's Avatar
I'd go with the full complete set from eBay. I picked up some partial pinstripes from Jaguar Heritage around 18 months ago & it turned out I got the wrong colour... there are 2 varieties of the red/silver later thin type... If I recall correctly the two variants are called Pewter (which is darker silvery-grey) and Quicksilver, with slightly different variations of red for each.
The Jaguar stock was also very old, & not all of it was available even then - the parts you definitely needed were the front wing sections. You could make up the door/rear front wing sections from lengths of rear quarter panel if you could get them.
AL NZ
Nov 20, 2015 09:51 AM
tberg
Aug 10, 2014 10:58 AM
LeftOver
Jul 16, 2012 08:38 AM
