Pulling Codes
Old Sep 3, 2012 | 08:53 PM
tiger38117's Avatar
Default Pulling Codes
Hello,
Trying to help a buddy of mine with his '92 XJS convertible...with a vested interest as I am thinking about buying it from him. I have tried to search here but I'm not having any luck.
The Check Engine light is on. Based on my searches, it looks like the codes can be retrieved through the tip computer...correct? What's the procedure for doing that? If that's not right, where's the plug for the code reader?
Old Sep 3, 2012 | 10:28 PM
howlinowl's Avatar
When you first key-up the ignition switch, the trip computer should show the fault code for a couple seconds before the clock comes up. When I first bought mine, a "FF44" would come up. FF44 refers to the right side O2 sensor. Replaced it, disconnect the battery to clear the code and reconnect the battery and it was good to go. Not sure if the trip computer would show multiple codes, or just one at a time (repair that, clear codes and restart and see if it throws another). Also, make sure you have the radio code to unlock the radio when you disconnect the battery.
howlinowl
Old Sep 6, 2012 | 11:27 PM
Sarc's Avatar
There is also a secret wire in an unmentioned loom behind the trip computer (I think from memory it's pink) This wire, when grounded cycles through all of the codes captured in the computer, then resets them all. I'm not saying I get a lot of FF codes, but let's just say I don't like having to reset all of the settings on my stereo every time I disconnect the battery, so I have this wire connected through a hidden switch in the right hand ashtray so I can flip the switch, review and reset all of the codes without disconnecting the battery.
Old Jun 26, 2016 | 08:36 AM
malc4d's Avatar
Got the dreaded FF44 code today.......
Tell me a little bit more about this pink wire ..
Old Jul 15, 2018 | 07:27 PM
Frank Grabovich's Avatar
what does code FF117 mean 1992 Jag XJS 12 CYL
Old Jul 15, 2018 | 08:07 PM
Old Jul 15, 2018 | 09:16 PM
malc4d's Avatar
Does it flash 11 then 7 ?
https://www.jaguarforum.com/showthread.php?t=40729
Old Jul 16, 2018 | 12:23 AM
Jagboi64's Avatar
If it's FF17, that means TPS (throttle position sensor) resistance is out of range. Below is the diagnostic procedure:
Old Jul 16, 2018 | 08:01 PM
mghirsch's Avatar
Talking
After several years, I finally solved my FF44 problem. Turns out an exhaust leak before the sensor can trigger it. Repaired the leak and the problem disappeared.
Bcrary3
Feb 21, 2023 04:29 AM
Jpav27
Jul 31, 2022 06:43 AM
Bcrary3
Sep 12, 2021 05:41 AM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
TexasCat
Sep 8, 2015 04:36 AM
