A puzzle
Old Jun 22, 2018 | 07:33 PM
JigJag's Avatar
Default A puzzle
Anyone have any idea why this would occur?
Driving along in Light traffic, 100kph, 30C, Efan On. Needle is sitting right at the top of the N. Maybe a touch above. I thought it higher than it should be, not bad, just odd. For some reason I switched off the efan. Needle iimidiately dropped to just above the bottom of the N. Right where I’d expect it to be in these conditions.
How? Why?
Heres a pic for your trouble.
Old Jun 22, 2018 | 09:46 PM
VancouverXJ6's Avatar
My car's temp needle moves up or down a good 1/8th of an inch immediately if I turn anything on/off, like even the fan on medium. Far too quick to reflect an actual increase or decrease in temps. It could be nothing more then a voltage issue affecting the gauge needle way too much. Can you replicate this while idling? Like say..for example.. using jumpers to attach a dead battery to your running car and see if that draw causes the gauges to move around?
Old Jun 23, 2018 | 04:50 AM
UMMMMM, Efan running backwards?????
Old Jun 23, 2018 | 06:33 AM
Daim's Avatar
What about just the current draw possibly causing the instruments to lose some ground connection? Check your terminals. Might just be an electrical gremlin. Without a PROPER temperature gauge running independantly of the instrument cluster, it can be hard to justify if the temperature increase is just a gremlin or if it actually IS a problem...
Old Jun 23, 2018 | 01:01 PM
JigJag's Avatar
Grant, nope! First thing I checked.
Certainly could be voltage change, but turning OFF a 17amp pull would make it rise if it were running low voltage right?
The drop I saw appeared to be a real reduction in temp. Not instantly. That was a poor word choice. It dropped over two seconds.
Im on other unrelated issues today. Four new injectors, a nos Vintage Performance GM module for the amp and a replacement vac advance unit. If it happens again after all that I’ll follow up with more details.
Old Jun 23, 2018 | 01:13 PM
Jagboi64's Avatar
At 100 km/h you shouldn't need a fan, the fan can actually act to block some air going through the rad. Can you replicate the drive with the fan off and see what happens? Or try driving with the fan off and then switch it on and see if the temp increases?
Old Jun 24, 2018 | 07:29 AM
warrjon's Avatar
I would see if you can replicate the issue,
Voltage variation will effect the gauges. A voltage drop should cause the gauge to read lower.
Old Jun 24, 2018 | 12:40 PM
EcbJag's Avatar
+1 to Jagboi64. The fan isn't effective at speeds above 50-55 km/h. At 100 km/h the spinning electric fan might have actually been blocking airflow.
jbudnick
Sep 20, 2014 10:54 AM
jagular
Aug 25, 2013 05:18 PM
Wolfy
Dec 10, 2011 01:17 AM
Peter M
Sep 17, 2010 03:58 PM
