Radiator blanking plug thread size
Old May 6, 2012 | 09:01 AM
Greg in France's Avatar
Default Radiator blanking plug thread size
I am considering a small modification to the radiator bleed system. To do this I need to use the LHS bleed plug female threaded fitting on the top of the LHS tank of the radiator: V12 1985 model.
This blanking (bleed) brass plug has a Whitworth sized hexagonal, and quite a fine parallel thread. I need to know what size and type of thread it is. Anyone know please?
Greg
Old May 12, 2012 | 06:02 AM
Greg,
Memory, this will be good, haha, is 7/16NPT. It is n odd thread, apparently COMMON in the States, but not here.
I think I have info somewhere in the shed, but with the numerous boxes of Mongrel Rover bits filling the shed it will be fun to find, but if you need it, so be it, I will dig around.
Old May 12, 2012 | 11:29 AM
Its OK, thank you Grant, no need to turn over the garage. It is 1/8 BSPP (BSP parallel, not tapered), as is the banjo bleed thread on the RHS rad tank . Actually, 1/8 NPT willl fit, but a tad looser than the BSP.
After much searching on the Google, I have found the fittings I need.
Greg
Forcedair1
Sep 8, 2025 01:57 PM
aholbro1
Dec 29, 2024 06:46 PM
1100me
Jul 24, 2023 06:10 PM
tberg
Sep 7, 2015 07:32 AM
RaceDiagnostics
Sep 7, 2015 07:28 AM
