Radio fuse on 1992 XJS
Old Oct 17, 2010 | 02:21 PM
Scoupe89's Avatar
Default Radio fuse on 1992 XJS
I have checked the radio, removed it looking for in-line. Have I got the wrong cig lighter/radio fuse? Is there a guide or print with the fuse #?
Old Oct 17, 2010 | 02:23 PM
Scoupe89's Avatar
Anyone able to check the owner;s manual on 1992? I found it on the XJ-SC there.
Old Oct 17, 2010 | 09:16 PM
Scoupe89's Avatar
Not #7 cig/checking each fuse...
Old Oct 19, 2010 | 09:17 AM
Sarc's Avatar
From the manual, Number 7 fuse, left front fuse panel (The ones under the dash)
Now, I have found mistakes in the manuals before, and I'm not phyiscally near my car so I can't go and check for you.
Whats the symptoms ? stereo not working ?
Old Oct 19, 2010 | 10:18 AM
Scoupe89's Avatar
Default Thanks!
Found it right away. I didn't know there was a driver's side fuse box also.
Tricky Jags!
Old Oct 20, 2010 | 07:12 AM
Sarc's Avatar
Good news!
By the way, you also have a smaller fuse box in the trunk and another small one under the hood. If you are ok reading electrical diagrams go to the FAQ sticky and click on the Electrical_diagram link. This goes to a great website that has all of the circuit diagrams in pdf format that you can download. Many XJS mysteries can be solved with these circuit diagrams (and / or a hammer)
Old Apr 22, 2011 | 04:25 PM
nathan88xj6's Avatar
does anyone no where the radio fuse for an 88 xj6 is and what kind of fuse to use
Old Oct 7, 2012 | 07:20 PM
Weeser1's Avatar
Thanks Sarc,
I did not know about the fusebox in the trunk or under the hood. The radio worked just fine until it was stored in the garage, over winter.Took the battery out as I live up North , in the spring , punched in the security code, radio worked by sight but no sound. Ever heard of this ? Is there a fuse for the speakers? Its a 1992 XJS .
philwarner
Oct 4, 2024 01:37 PM
BadKat174
May 26, 2023 12:29 AM
leep123
Sep 26, 2015 04:53 PM
tvholden
Sep 12, 2015 11:13 AM
Greg Reed
Sep 9, 2015 07:20 PM
