radius arms
Old Oct 18, 2010 | 06:41 AM
Dom's Avatar
Dom
Default radius arms
New to forum and I have purchased a 94 xjs convertible that needs a little work. I am removing the radius arms off the rear suspension. The bolt that holds the radius arm to the rear axle does not clear the shock mount in order to remove the radius arm. There must be an easy solution but I don't know it.Please help.
Old Oct 18, 2010 | 12:16 PM
ilfordboy's Avatar
Dom, Welcome to the Forum, I do not have the answer, but am also in the process of getting a 95 XJS....so any helpful pics or tips you post here would be great.
Hopefully, some other members will be in a position to help with the radius arm issue you have.
Cheers.
Old Oct 19, 2010 | 09:03 PM
nosox's Avatar
Hi Dom and welcome. That bolt should have one corner of the bolt head ground off. Line up the ground part and it should JUST clear the mount. Good luck and let us know how you make out.
As an aside, mine was so rusted inside the bushing I had to cut it out.
Old Oct 20, 2010 | 11:11 AM
ken@britishparts.com's Avatar
Have spare bushings to replace and get a bigger pry bar. Brute force is the answer here. Make sure the kids aren't around, your language will not be good.
wichita
E type ( XK-E )
Apr 16, 2016 04:00 AM
Dave1109971
Dec 15, 2015 06:16 PM
Dave1109971
Oct 2, 2015 06:11 PM
Blake04VDP
Sep 28, 2015 05:20 PM
Camnelson324
Sep 27, 2015 08:48 AM
