Rear Brake Bleed Nipple Rounded Off how can I get it undone?
Old May 17, 2018 | 05:20 PM
orangeblossom's Avatar
Default Rear Brake Bleed Nipple Rounded Off how can I get it undone?
Hi Guys
I was trying to undo the Rear Brake Bleed Nipple on 'The Ice Princess' using the correct size 11mm Socket
And one of them undid no problem, although it was a bit stiff, although I would add that I have been Soaking these in (The Mixture) Penetrating Oil
But when I came to undo the 2nd one, it was very tight and the Brake Nipple Nut rounded off
I tried to Hammer a smaller socket onto the Bleed Nipple but there isn't any room to hit it hard enough to try and force it on
I don't want to drop the rear cage, unless I absolutely have to, so any ideas as to how I can get it undone
Also I've heard of a Tool that looks like a drill chuck with a handle, which is a self tightening Wrench, which is ideal for that very job but I cannot remember the name of it or where I can get one
Old May 17, 2018 | 06:03 PM
icsamerica's Avatar
Mini pipe wrench, tight fit up there though.
Weld on a 5/16 nut.
Try a rouded of nut socket like this...
Amazon Amazon
Might help to heat it up with a torch, cool it with a drenched and wet towel, rapid heat cycle will create cracks in the rust. Hit the caliper with a hammer to create cracks in the rust. Then retry
Old May 17, 2018 | 06:28 PM
Hi icsamerica
I did try heating it up even before I tried to undo it, maybe I'll try welding a nut on the Top, where hopefully the heat might break it free
Old May 19, 2018 | 06:09 PM
warrjon's Avatar
Vice grips then replace the nipple. If this fails remove the caliper and drill it out carefully smaller then threaded hole then re-tap hole to remove the rest of the nipple.
I always use ring spanners when ever possible as there is far less chance of rolling the nut. I only use use open spanners when a ring will not fit.
Old May 19, 2018 | 06:19 PM
Daim's Avatar
There are actually brake caliper ring spanners, which I have. Basically a ring spanner with a small cut out. Like a combined open end and ring spanner. Best things to use.
Old May 19, 2018 | 06:51 PM
sidescrollin's Avatar
Seconding vice grips! Crank that sucker down
Old May 20, 2018 | 01:51 AM
Hi Daim
Brake Caliper ring spanners are no good if the Bleed Nipple has rounded off
Old May 20, 2018 | 01:53 AM
Hi Warrjon@Sidescrollin
Good idea except that the rear muffler will have to come off, the exhaust pipe is right in the way
Old May 20, 2018 | 04:05 AM
Daim's Avatar
Originally Posted by orangeblossom
Hi Daim
The avoid rounding it off in the first place
michaem101
Jul 31, 2019 04:28 AM
iownme
Feb 24, 2019 05:20 PM
azeteg
Aug 3, 2014 05:58 PM
Leonard_85
Apr 26, 2014 12:34 PM
sogood
Sep 16, 2011 05:20 PM
