Remove pinstripe?
Old Sep 1, 2018 | 10:15 PM
VancouverXJ6's Avatar
Default Remove pinstripe?
Has anyone else removed the pinstripe on their car? I need to carefully scrape mine off as the clearcoat is failing around it. I don't want to scratch it up anymore than necessary, and removal via cleaners might be too harsh.
Old Sep 2, 2018 | 04:35 AM
Jagsandmgs's Avatar
The failing clearcoat probably rules out conventional methods, but pin stripes can be removed with a pinstripe removal tool: 3M 03612 4" x 5/8" Adhesive Eraser Wheel https://www.amazon.com/dp/B005RNGN8I/ref=cm_sw_r_cp_api_L66IBbR0SSCX7
Old Sep 3, 2018 | 03:35 AM
bladerunner919's Avatar
I've done it on a different car using a hairdryer to warm it up and soften the adhesive, and a plastic scraper (old credit cards work well) to remove it.
Old Sep 3, 2018 | 01:39 PM
sidescrollin's Avatar
A plastic scraper can work, leaving minimal buffing work. The last time I did one, a heat gun only got the majority off in the big pieces. What didn't come off with a scraper I used 2000 grit on, then I buffed the whole thing out with compound and polish.
My original stripe on my XJS is flaking off badly, and would likely come away easily with a scraper. Any amount of sanding is going to bring on the clear coat peeling faster, but you have to just get used to the fact that ones it goes, it goes. It is all the same age and the only variance in the failure is the exposure to the sun due to angles and variations in paint thickness.
Old Sep 3, 2018 | 01:59 PM
Jagboi64's Avatar
I second using the 3M wheel. It's specifically designed for this task and works well.
Old Sep 4, 2018 | 09:10 PM
Ezrider's Avatar
i 3rd the 3m eraser wheel there a bit proud of them but worth every penny compared to alternative methods.
Old Sep 7, 2018 | 12:40 AM
user 652867429824's Avatar
I have had success with a hairdryer set to the hi setting and a plastic scarper, and as stated earlier an old credit card works well
Old Sep 7, 2018 | 01:29 AM
Keesh's Avatar
Sometimes this pinstripe uses as dividing line for partially respraying.
Bondy
Nov 10, 2020 01:28 PM
desertchimera
Jan 14, 2014 04:47 AM
Sleek N Subtle
Aug 30, 2013 12:15 PM
Padrino
Jul 3, 2013 08:21 AM
Raunaq23
May 6, 2013 09:30 AM
