Replacing hoses 1996 XJS AJ16
Old May 24, 2018 | 04:03 PM
Fesiwig's Avatar
Default Replacing hoses 1996 XJS AJ16
Good afternoon,
Any tips on changing the hoses on a 1996 XJS; particularly the one running from behind the water pump that runs under the intake manifold? I've seen one post where the fellow just removed the intake and I'd rather not do that but it looks like a bear to change otherwise. Would like to hear from someone who has replaced that hose. Any other tips regarding changing the hoses and flushing the system would be appreciated.
Thanks, Mitch
Old May 24, 2018 | 07:26 PM
Vee's Avatar
Vee
I’d be interested in tips for the AJ16 engine as well.
I was lucky enough to change the ******* hose out when I replaced the intake manifold gaskets, but all other hoses are likely original.
Old May 24, 2018 | 08:54 PM
Time-Pilot's Avatar
Replaced that hose on my XJR, just remove the manifold and be done with it.
Old May 25, 2018 | 02:26 AM
SleekJag12's Avatar
Default Manifold off?
It is downright easy once the manifold is off! While you're at it, replace whatever else suits you. Namely, the two coolant pipe gaskets!! {EDIT: Part# EAC9745} ... Easy. I also put in a starter and repaired a section of heater take-off hose. You might do the lower hose or the oil sender gasket too. I think the most difficult part was removing the wiper mechanism to get clearance. No need to disconnect the harness to the coils or injectors, leave all that connected to the intake manifold and runner. You'll get a new intake manifold gasket installed then. A good cleaning might be in order down there too!
The Dayco part # for the bypass hose is 71666. Also called the DEVIL hose.
There is information in the X300 section about doing this job without manifold removal. Access is a real devil.
Attached Thumbnails Replacing hoses 1996 XJS AJ16-20140206_175329.jpg   Replacing hoses 1996 XJS AJ16-20140116_163616.jpg
Old May 25, 2018 | 07:54 AM
Jagsandmgs's Avatar
I found no need to remove the manifold, but I did remove the air cleaner, airflow sensor, and some sort of plastic pump looking thing above the alternator to get at the back of the water pump.
I’ve done this twice now... once when the hose burst, and then more recently when the water pump started leaking (190000 miles!). The second time was made much easier to remove because the first time I’d used radiator hose grease on all connections. AutoZone sells it in little packets labeled as radiator hose grease, or you can get a tube of it but it’s labeled AGS Sil-Glyde Brake Lubricant. Same stuff though, just a rubber safe silicon grease. Keeps the hoses from getting stuck on. Also makes them simpler to push on.
Old May 25, 2018 | 07:56 AM
Vee's Avatar
Vee
Originally Posted by SleekJag12
Namely, the two coolant pipe gaskets!! EBC9634.
I looked that part up, and it doesn't appear to be used on the AJ16 engines, just the 5.3 and 6.0 v12 engines...but your pictures look like you have the 6 cylinder....are you sure you gave us the right part number?
Thanks.
Old May 25, 2018 | 07:58 AM
Vee's Avatar
Vee
Thank you for this information! I happen to already have a tube of this! I rarely use it because brake pads (that I seem to buy) always come with a little packet of lube! I never knew that I could use this for hoses...this is very useful for me. Thank you.
Old May 26, 2018 | 01:48 AM
SleekJag12's Avatar
Default Corrected!
Thanks.
My apologies. The correct gasket part number is EAC9745. I corrected my original post. Those pictures are from my AJ16 Vanden Plas. The setup of the AJ16 XJS is a bit different but the water rail and gaskets are the same. Thanks for pointing this out. It will be interesting to discover all the differences when I become an XJS owner someday!
AJ16 XJS water rail, pipes and such:
Old May 26, 2018 | 06:29 AM
Vee's Avatar
Vee
Gahhhh! I wish I had know about this part when I had that manifold off, I certainly would have replaced it.
oh well.... thanks for showing me that!
Hitch
Aug 23, 2017 10:07 AM
Roger95
Dec 16, 2015 09:09 AM
zoranwalker
Nov 29, 2011 05:41 AM
jaginblack
Jul 21, 2010 07:59 AM
Amadauss
17
Apr 6, 2010 07:29 PM
