Replacing Window Switch’s
Old Dec 10, 2023 | 05:16 PM
Mbower1967's Avatar
Default Replacing Window Switch’s
1993 XJS Convertible
Any guidance on how to replace console switches like the convertible and l/r power window switches? Bought new ones to replace operating ones but that just had a lot of wear and tear on them.
Old Dec 10, 2023 | 05:37 PM
ptjs1's Avatar
Mbower1967,
You really need to lift the centre console veneer and then release the locating tangs from below to remove the switches.
Good luck
Paul
Old Dec 11, 2023 | 07:15 AM
Vee's Avatar
Vee
1. Remove the armrest cubby. I think it’s about 5 phillips screws.
2. This exposes the 1 phillips head screw that keeps the ski slope in place. Remove.
3. Tilt up the ski slope so you can access the window switch assemble from below….
you should know what to do at that point.
Old Dec 11, 2023 | 01:28 PM
Mbower1967's Avatar
Bee, these are exactly the instructions I was looking for. Will tackle this weekend. If you think of anything further that would help please let me know.
Old Dec 11, 2023 | 03:09 PM
Mbower1967's Avatar
Vee, I’m sorry darn auto correct.
Old Dec 11, 2023 | 04:53 PM
AZDoug's Avatar
My 1988 car has a couple fasten points also, one on each side, you access them by removing the ashtrays. They are U shaped brackets, so don't take the screws all the way out, if your car has those. Saves dropping a screw into the harness mess underneath.
Doug
Old Dec 12, 2023 | 08:15 AM
leep123's Avatar
Doug
Ditto on the U shaped brackets.
I also have a vague recollection of having to pries out the catch receptacle for the armrest in order to remove the metal bracket that spans across the very rear of the ski slope but it was a while ago when I did this.
Cheers,
LeeP
Old Dec 12, 2023 | 10:09 AM
Vee's Avatar
Vee
You shouldn't have to remove the ski slope, just tilt it high enough to unplug the two or three switches you have, and then pry out the entire bezel assembly. then do what you want. Just make sure you remember which plug is which! They are all the same, so you run the risk of plugging the drivers side switch to the passengers side plug.
Also, if you bought the cheap replacement switch with the plastic tabs, the only way I was able to squeeze the switch into the bezel was after heating the tabs up on the switch with a hairdryer.
Old Dec 12, 2023 | 10:21 AM
Edelweiss's Avatar
Phillips, or Pozi-Drive?
Old Dec 12, 2023 | 11:08 AM
jal1234's Avatar
If it's original, Pozidrive.
Old Dec 12, 2023 | 11:16 AM
Edelweiss's Avatar
Yep. My basic rule is always grab the Pozi screwdriver first. Only when that doesn't work do you grab the other...
Zarathushtra
Nov 5, 2023 12:59 PM
badicedog
Jul 21, 2023 09:49 PM
carlprs
Aug 3, 2022 09:31 AM
Todd Wiens
Aug 26, 2021 03:53 PM
JayJagJay
May 20, 2021 06:32 AM
