Rescue's Official Build Thread - 88 XJS V12 Oct 12 2019
Old Nov 7, 2019 | 07:12 AM
  #181
JayJagJay's Avatar
Some of the caliper sets will COME with pads, under 60, 70 bucks after core return. If I remember correctly.
Old Nov 7, 2019 | 07:23 AM
  #182
ptjs1's Avatar
Originally Posted by Rescue119
I dont know that's why I'm asking lol. Maybe the caliper pistons sit inside of them?
They look like the bushes on the rear end of an outboard disc late car that sit inside the caliper to mount.
So, nothing to do with the front end.
Paul
Old Nov 7, 2019 | 07:39 AM
  #183
JayJagJay's Avatar
Oh!
I see what y'all are talking about. Those are the little press fit guides (rubber),,,, filled with grease,,, for the moving parts (the pins) of some calipers. They have little toothed caps. Used to shield the rider pins on the inner moving section of the caliper... And no,,,, I don't think you'll be needing these for a xjs front brake caliper.
Old Nov 7, 2019 | 07:47 AM
  #184
Rescue119's Avatar
Originally Posted by JayJagJay
I'm reading "CALIPER BRUSH", to brush off dust and dirt... They are trying to sell you something extra... Up sell...
If you pop the pistons out of the calipers be very careful on inspection. If the car sat a long time, I think you said it had, the cylinder walls and pistons themselves can be very messy and creating a seal can be tough. Money certainly WAS an object for me,,, but I out and out replaced all four calipers front and back and kept it moving. That IMHO is worth the $$$$. Rock also has a great core charge policy...
Grant has a lot of good things to say about the front end and brakes, bearings, and shims. Not as easy and straightforward as a Corolla by any means.
I'm hoping I dont have to rebuild the calipers. Just give then a good cleaning and paint.
I was just selecting everything under the brake section lol.
Saturday is when I'll starting pulling it all apart. Gonna start with the lf as that's the only one that doesnt seem to be sticking lol.
Old Nov 7, 2019 | 08:50 AM
  #185
anyoldiron's Avatar
Banned
Hows this look for front end brake job?
.................................................. ....it looks like the easy part.
Old Nov 7, 2019 | 09:27 AM
  #186
JayJagJay's Avatar
(Grinnnnning)....
Old Nov 7, 2019 | 11:14 AM
  #187
Rescue119's Avatar
Lol when you are not in a rush it's easy. I'm giving myself 2 months for front end.
Old Nov 17, 2019 | 07:45 AM
  #188
Rescue119's Avatar
So I've been trying to wrap my brain around why this bolt (in red #10) wont go into its home (in red #15). It just wont catch at all. I've tried everything. It's a tight spot but I can get it into position with some extensions etc. I'm wondering if the threads in #15 got messed up. I was thinking if I can get a tap into it maybe I can repair it.
So does anyone know the tread type/size of this bolt?
Old Nov 17, 2019 | 10:12 AM
  #189
Greg in France's Avatar
I am pretty sure it is a UNF thread. Undo 13 and detach 3, and you can pull down the item and get at it better. grinding a 45 degree taper onto the bolt threads often helps, and you can get it started and then remount everything before tightening it up.
Old Nov 17, 2019 | 10:21 AM
  #190
Rescue119's Avatar
I did file the end of the bolt to see if that would help. I'm was hoping not to remove #13 because its tight As it is. But looks like you might be right Greg. Ugh. Oh well such is life. I'm already looking forward to spring to see this car move under it's own power
Old Nov 17, 2019 | 05:06 PM
  #191
Rescue119's Avatar
Well I ordered a set of posi bits and they came in today. Also cleaned up the mess I made over the past too weeks. So now I'm ready to take the front end parts off.
Old Nov 17, 2019 | 11:19 PM
  #192
Dukejag's Avatar
Dont forget the pictures....looking forward to seeing this evolve.
Old Nov 23, 2019 | 01:16 PM
  #193
Rescue119's Avatar
It begins. I've seen worse. Hoping once i start removing everything it wont be that bad lol. Everything is soaking right now. Just the LF side. No rush. Spring is 6 months away lol
Old Dec 4, 2019 | 04:31 PM
  #194
Rescue119's Avatar
From the mobile game top rides lol
Also have seen they have the 77 trans am one.
Old Dec 12, 2019 | 04:09 PM
  #195
JayJagJay's Avatar
Brotha Rescue!!!???
Where ya at? Everything ok with them front brakes?
Old Dec 13, 2019 | 04:20 AM
  #196
Rescue119's Avatar
Brotha Rescue!!!???
Haha ya. I havent had time at all with work. But I'm off for 2 weeks at xmas so I'm hoping to get at it then.
Old Dec 13, 2019 | 08:48 AM
  #197
JayJagJay's Avatar
Right O!!! Don't let your momentum get extinguished!!! It's hard to reignite, lol... That's prolly what happen to the last owner
Old Mar 4, 2020 | 11:57 AM
  #198
Rescue119's Avatar
Im Still alive. work got in way. I got 2 weeks of leave coming up and im gonna tear into this.
Old Mar 9, 2020 | 10:48 AM
  #199
Rescue119's Avatar
So started the front brakes. Think I can rebuild the calibers lol. No wonder they are all stuck.
Also how do I plug the brake line so i can stop fuild from dropping out. I've tried a nail and tape but it just keeps leaking lol.
Time to remove the disc
Old Mar 9, 2020 | 01:07 PM
  #200
Rescue119's Avatar
So got the driver side all off. Man those hub bolts are in a tight spot. I didnt think I was gonna get then out. Took some maneuvering and my 220lbs on the wrench to break them loose lol. Anyways here's it apart. Also #4 in the last doesnt exist on my hubs. Did they stop doing that in 88 and just made it so you greased everything before you reassembled?
Hopefully someone is reading this still lol.
I'm off the next 2 weeks so gonna try and get stuff done.
Also got a guy coming to appraisal so I can finally get the car actually put in my name lol.
