right and left bank air intake
Old May 18, 2012 | 07:25 AM
Qgregg's Avatar
Default right and left bank air intake
Just noticed on the right bank(passenger side) air intake, i cannot feel the suction. I held a piece of paper to the left intake and could notice the suction but not on the right. im baffeled should'nt both sides have substancial suction??? Note*(Just replaced alternator, and radiator)
Old May 18, 2012 | 07:59 AM
M90power's Avatar
the left bank gets its idle air from the AAV, which is routed through the airbox on that side. the right side gets its air from the corssover.
open up those gaping throttles and i guarantee youll feel the force. lol
Old May 18, 2012 | 08:12 AM
Doug's Avatar
What M90 is saying is that your car is normal :-)
Old May 18, 2012 | 08:14 AM
Qgregg's Avatar
Default right and left bank air intake Reply to Thread
thank you, glad to know. I Also noticed a hose laying almost on top of the distributer and also a hole in the dist. cap, does your dist have a vaccumm hose of some type on it???
Old May 18, 2012 | 08:15 AM
Qgregg's Avatar
wonderful, makes me feel well today Doug.
Old May 18, 2012 | 08:20 AM
M90power's Avatar
I believe its a timing reference hole, so that you dont have to take the cap off to see where the rotor is pointing. the vacuum hose sticks out of the side of the metal diaphragm, underneath the distributor cap, and is pointing towards your 6a spark plug
Old May 18, 2012 | 08:27 AM
Qgregg's Avatar
let me run out and check that, ill let you know. Cause when i give it gas its breakin down somewhere.
Old May 18, 2012 | 08:33 AM
JameyXJ6's Avatar
There is a hole on the top of the dist cap for a vac hose and another on the side for an air inlet. These distibutors will build up gasses inside and will ignite explosively and blow the cap off. The vac lines just suck any fumes out before it reaches that point.
Old May 18, 2012 | 08:37 AM
M90power's Avatar
LOL, thats crazy.
Qgregg's Avatar
ok heres what i see, underneath the dist cap pointing towards the windshield is a white piece of plastic sticking out as if a hose should be covering it, now the loose hose also has a white plastic fitting coming off of it. im not sure if there was a little piece of hose in between to fit the two together or not i dont see any piece of hose down in there.
Old May 18, 2012 | 08:40 AM
Doug's Avatar
That the distributor vent hose.
There should be two small hoses to the distributor. One goes to the AAV hose to provide a small amount of vacuum. The other goes over towards the left fender and has a small air filter attached....looks like a small fuel filter.
Anyhow, the vacuum draws filtered air into and through the distributor for venting
JameyXJ6's Avatar
The one on the side had a short line on it and a small filter like a fuel filter on the end. The port on the cap has a vac line.
Old May 18, 2012 | 09:15 AM
Qgregg's Avatar
could this hose being off cause lose of throttle power?
Old May 18, 2012 | 09:19 AM
Greg Edge's Avatar
No
Old May 18, 2012 | 09:39 AM
Qgregg's Avatar
shoot, i just replaced radiator and alternator, and for some reason now when i give it the gas its bogging somewhere. Can't figure what i forgot to connect back up. seems like all is back where it was.
Old May 19, 2012 | 05:21 AM
JameyXJ6's Avatar
Check the vac lines underneath the throttle body. You might have accidently knocked one off!
Old May 22, 2012 | 10:08 AM
Qgregg's Avatar
i looked underneath the throttle bodies (or felt) no hoses under mine
only on top.
Old May 22, 2012 | 10:17 AM
JameyXJ6's Avatar
Directly under the butterfly on each side you should at least have ports. Mine is an 83, and my parts manifolds are 85 and they both have ports.
Old May 22, 2012 | 10:31 AM
Qgregg's Avatar
ill take another look see, do i need to pull the air filter covers off to see better?
Old May 22, 2012 | 10:41 AM
JameyXJ6's Avatar
I don't think you can see them without a mirror or something, and it would definitely be easier with the airboxes removed.
