right and left bank air intake
Old May 22, 2012 | 12:32 PM
Qgregg's Avatar
ok, ill will look again, after work and post back, tks
Old May 22, 2012 | 12:35 PM
Qgregg's Avatar
yea really strange, i had to knock some hose loose. She was running great, even the idling was getting real close to normal. now when i give it gas its gogging somewhat, and is really idling high 1500 when cold starting and settles at about 1200, or 1300 or so.
Old May 22, 2012 | 12:38 PM
JameyXJ6's Avatar
Sounds just like a vac leak to me!
Old May 23, 2012 | 07:08 AM
Qgregg's Avatar
ok,( i found a disconnected hose ) on the aux air valve is a hose coming off 3/4or so, then off of this hose is a smaller attached hose. its going to nothing it looked as if it was running over towards the dist. i see nothing to attach it to.
Old May 23, 2012 | 07:32 AM
Qgregg's Avatar
tHE BIG HOSE IM TALKING ABOUT IS NOT THE ONE COMING OFF THE TOP
Old May 23, 2012 | 07:35 AM
Doug's Avatar
I don't entirely understand your posting but one of the AAV hoses has a a smaller hose piggy-backed to it. That smaller hose goes to the distributor as part of the distributor vent system.
Old May 23, 2012 | 07:41 AM
Qgregg's Avatar
That would be the one, the one thats piggy backed, except that would have no bearing on the high idling or bogging down when given accelleration. With that being assumed. there is one more hose that is not connected and it is the one that has the air filter looking gadget on it above the left fender well, it runs toward the windshield takes a left towards the passenger side then stops 1/2 way of the engine bay and is not connected to anything.
Old May 23, 2012 | 08:17 AM
  #28
JameyXJ6's Avatar
The line with the filter is also connected to the distibutor. One connects to a white-ish plastic tube on side of dist facing firewall, the other connects to the top of the dist cap.
Old May 23, 2012 | 08:39 AM
Qgregg's Avatar
which one is which????
Old May 23, 2012 | 08:40 AM
  #30
Qgregg's Avatar
and do they need to be connected? and also could this be the cause of any idling issues??
Old May 23, 2012 | 10:39 AM
  #31
Greg in France's Avatar
The purpose of them is to prevent an explosion in the dizzy, caused by the build up of inflammable gasses. So I believe they are rather important. The system does not cause idling problems. If yours is disconnected, you can be sure the pipe it is meant to be connected to (under the LHS intake manifold, part of the AAV rubber tubing connecting the AAV to the LHS airbox) is drawing air straight in, rather than drawing it through the dizzy first!
Greg
Old May 23, 2012 | 10:40 AM
  #32
Filter one goes to the side of the dizzy, the AAV one to the dizzy top.
Greg
Old May 23, 2012 | 10:53 AM
  #33
Qgregg's Avatar
greatfull, thank you much. All vacuum drawings i could find, i could not tell what went where.
Old Apr 23, 2014 | 07:53 PM
  #34
1800doogie's Avatar
Default Unisyn?
With all this said, will a Unisyn carb equalizer work on these motors?
Old Apr 24, 2014 | 10:31 AM
  #35
sidescrollin's Avatar
the XJS is fuel injected
on a 4 carb v12 like an XJ12 or XKE you could probably use one but you would be much better with a proper gauge and not that little ball on the unisyn, its just not as accurate. If your question is related because the thread is about the suction not being equal, the intake and vacuum system on a fuel injected setup is entirely different and this difference in suction wouldn't be seen on a carb'd v12 (vacuum routing different, no AACV,etc)
Kevin Burnaby
Jun 28, 2020 08:04 AM
cissdm
May 3, 2016 06:02 AM
OkieTim
Sep 8, 2015 04:48 PM
1100me
Sep 7, 2015 06:26 AM
OkieTim
Sep 2, 2015 12:48 PM
