Routing a wire
Old Jul 17, 2018 | 08:33 AM
Segfault's Avatar
Default Routing a wire
I'm trying to figure out the most pain free way to route a wire from engine compartment to the main fuse box and so far I'm failing. Too many things on the way. Has anyone hints or tips how to do it? Shall I drill a hole somewhere?
Old Jul 17, 2018 | 08:48 AM
Daim's Avatar
What year is the car? Iirc certain years have more or less openings. You can try to use the main harness grommet left/right side of the enging bay.
Old Jul 17, 2018 | 11:14 AM
Segfault's Avatar
Year is in my signature, 1986. It looks like the main harness does not go straight thru, there is a multi-wire connector. Does not seem useful.
Old Jul 17, 2018 | 01:19 PM
J_C_R's Avatar
See attached photo.
This is of my '87. I removed the body plug, and that will allow you access to below the driver's side (on a LHD car) dash board.
I just ran another wire though it today. I still need to cut a grommet, slip it over the wires, and seal it so the wires don't chafe against the body.
Old Jul 17, 2018 | 02:15 PM
Segfault's Avatar
Thanks! Yes I saw that hole, but I couldn't figure out where to look inside of the car. Will give it another try.
Old Jul 17, 2018 | 03:39 PM
J_C_R's Avatar
Just stick a coat hanger or some other stiff wire in it. It'll come out somewhere between the bonnet handle and the brake pedal.
Not trying to be insulting here, but if your are connecting to the battery bus that runs along the engine firewall, be aware that the bus IS NOT fused in any way. A mistake here could be very exciting...
John
Old Jul 17, 2018 | 03:50 PM
Segfault's Avatar
No, I'm aiming for fuse box. Anyhow, you have much more space there, I have clutch main cylinder on the way. Will investigate further when it cools down.
Old Jul 17, 2018 | 08:14 PM
Segfault's Avatar
Success! Thanks a lot. Without you I could've never known there is a grommet.
Old Jul 18, 2018 | 03:59 PM
warrjon's Avatar
Be careful routing the wires there. I did this with my cruise control wiring then found the wiring fouling on the bonnet release cable. It can be done, I re-routed mine on the inside to keep it away from the bonnet mechanism.
Pristine97XK8Convertible
Feb 7, 2018 10:16 AM
jal1234
Jul 27, 2016 06:27 PM
Doug
Jun 13, 2016 06:21 PM
Thermite
Nov 5, 2015 11:18 AM
e21pilot
Jan 20, 2012 05:38 PM
