A slight touch of brown lace
Old Apr 25, 2014 | 11:24 AM
Steve M's Avatar
Default A slight touch of brown lace
A minor problem, luckily it has just had an MOT.
Looks like it has been kept in a lake! A salt water one.
Attached Thumbnails A slight touch of brown lace-img_1779.jpg   A slight touch of brown lace-img_1780.jpg
Old Apr 25, 2014 | 11:58 AM
If MOT inspectors are as tough and unrelenting as reports lead me to believe, How in the World did this get past them???
I haven't seen a suspension component in that condition on any car still on the road!
Old Apr 25, 2014 | 12:36 PM
ptjs1's Avatar
Steve,
That's the front subframe removed from the car isn't it? In which case, that's the typical type of XJS front subframe corrosion that can't be seen with the subframe in situ. And as you know, most MoT testers wouldn't be aware of it or know how to look for it.
There are probably a number of XJSs running around with similar problems!
At least with a new MoT, you can fix the problem and then put the car straight back on the road without retesting it!
Good luck
Paul
Old Apr 25, 2014 | 12:38 PM
Steve M's Avatar
I know, cool huh? Although to be fair it's not actually a suspension component, it's just the bit that all the suspension components are bolted to!
Also to be fair that section is only visible once the whole lot has been dropped; it looked fine from underneath.
The 'list' is getting ever longer!
Old Apr 25, 2014 | 12:42 PM
Steve M's Avatar
'The Man' is going to have it retested once all 'The Work' has been done just to be sure that everything is ok; all very noble but not helping on the wallet front!
Old Apr 26, 2014 | 08:56 AM
Steve M's Avatar
Brown lace to be replaced with silver necklace!
Attached Thumbnails A slight touch of brown lace-img_1797.jpg   A slight touch of brown lace-img_1798.jpg
Old Apr 26, 2014 | 09:13 PM
Much better.
Old Apr 27, 2014 | 04:53 PM
ronbros's Avatar
question; if the car has that much rust ,what must the rest look like?
Old Apr 27, 2014 | 08:07 PM
Steve M's Avatar
The rest looks absolutely fine, that's the annoying thing. Usual repairs to radius arm mounts of course but sills, wheelarches etc all good.
Finbarr1975
Sep 5, 2025 08:38 PM
jimforrest (uk)
Feb 28, 2019 06:42 PM
Larry-Cleveland
Feb 9, 2019 03:17 PM
Finbarr1975
Oct 4, 2015 05:32 PM
Glenn Barickman
Oct 1, 2015 04:09 PM
