so what to do-no one has a tps switch?
Old Sep 9, 2013 | 09:24 AM
ukester's Avatar
Default so what to do-no one has a tps switch?
lucas part # 73384-1992 xjs v12. Do I buy a 3 prong and splice it into my end that goes into the cars harness?
Old Sep 9, 2013 | 09:34 AM
Doug's Avatar
Not sure if I understand the question.
Do you have the later red TPS or the older black type?
Have you looked for part number EAC9634 ? It's the newer red type. Should still be available. Has three wires...
Old Sep 9, 2013 | 09:39 AM
Doug's Avatar
Or are you looking for the DAC7427?
Old Sep 9, 2013 | 09:41 AM
ukester's Avatar
it is red 3 wires and a connector that looks green
Old Sep 9, 2013 | 10:07 AM
AllanG's Avatar
It should be DAC7427 if it's a 5.3L facelift car.
Looks like it has been discontinued, perhaps try grublogger in UK for a used one?
Cheers,
Allan
Old Sep 9, 2013 | 10:45 AM
Doug's Avatar
I have to wonder what the difference is between the 9634 and the 7427.
Subtle and insignificant.... or obvious and very significant?
Old Sep 9, 2013 | 11:29 AM
AllanG's Avatar
Maybe the physical mounting? Electrically they are connected identically with the same voltage range on the wiper. Or perhaps they just changed supplier?
Cheers,
Allan
Old Sep 10, 2013 | 08:05 AM
ukester's Avatar
well looks like this car will not get any use the rest of the year. hard to think a electrical part that does need replacing no one has. as far as mounting it looks the same as early years-its the way it connects to the cars harness that is way different. the connector still has only 3 wires but some of the tps switches I have seen with that connector use 5 or 6 wires.
Old Sep 10, 2013 | 08:20 AM
AllanG's Avatar
You would think so, especially with over 115,000 cars built!!
I believe the 6 wire switches were for the My94-96 6.0L. It used a twin track potentiometer. One track sends position signal to the ECM and the other to the transmission controller. (The 4 speed tranny was electronically controlled)
Cheers,
Allan
Old Sep 10, 2013 | 08:28 AM
Doug's Avatar
Shoot, if the electrical operation/range is the same that's the most important part. I wonder if Kirby's book makes any mention of 9634 vs. 7427 and backwards/forwards usage?
Old Sep 10, 2013 | 08:36 AM
AllanG's Avatar
When you say connecting to the harness is different, are you talking about the plug itself?
If so and the potentiometer itself physically fits, then yes, you should be able to just splice your existing plug to the new pot. The outputs are the same, just look on the wiring diagrams to see if the wire colours changed.
This is a pic of EAC9634 which is available.
Cheers,
Allan
Old Sep 10, 2013 | 08:48 AM
Doug's Avatar
If you wanna use the car rather that wait don't give up too soon. My gut feeling is that an earlier TPS can be used.....perhaps with minimal fiddling about. Might be worth some research.
Heck, I used a Mustang TPS on my XJS.
When a part goes to "NLA" status it's usually because of A) lack of demand where continued production isn't justified or B) the manufacturer/supplier has gone belly up.
A bit of wire splicing might be all that's needed to get the car back on the road.
Old Sep 11, 2013 | 10:45 AM
ukester's Avatar
pics
Attached Thumbnails so what to do-no one has a tps switch?-tps-007.jpg   so what to do-no one has a tps switch?-tps-008.jpg
Old Sep 11, 2013 | 10:46 AM
ukester's Avatar
I have red-green-black splice them into red-red green-green and then black into yellow?
Old Sep 11, 2013 | 11:29 AM
AllanG's Avatar
Yep, sounds right. If you want to test,
Black = Ground
Green = 5v when ignition on
Red = wiper, should vary between about .3v to 4.5v depending on throttle position.
Cheers,
Allan
Old Jun 8, 2018 | 06:34 AM
Ollie2576's Avatar
Hi all,
I'm hoping to revive this thread. My 92 XJS wants a new TPS - Throttle Position Sensor (Potentiometer). The older EAC9634 with the 3 prongs is widely available, but the correct sensor for the 92 is impossible to get - it has a blue / green plug and is DAC7427. The DAC is still 3 wire with a different connector as far as I can tell, so I'm wondering if anyone has successfully done the splice with the EAC into the DAC plug with it actually working. I see discussion about it, but no stories on it working.
I'm running with a bad one at the moment. Check Engine is on and it doesn't run great, but it runs. My guess is many of us 92 XJS have the same issue. I thought I'd figure this out on my own and report to you all, but here I am.
Old Jun 8, 2018 | 09:18 AM
Greg in France's Avatar
Read this thread
https://www.jaguarforums.com/forum/x...ac7427-175118/
Old Jun 8, 2018 | 11:07 AM
Fla Steve's Avatar
Just a question for future reference. How do you know if the TPS is going bad?
I haven't learned about my 90 model diagnostics yet. So if it throws a code how do I retrieve it? I have a code reader with OBD II and an assortment of OBD 1 plugs. Is there even a diagnostic plug to plug into on a 90?
Old Jun 8, 2018 | 01:25 PM
Doug's Avatar
From a diagnostic standpoint? You'd check it with a voltmeter
No plug that I'm aware of. I don't think any form of OBD was provided until the facelift models came out, 1991/92. Others will chime in
Old Jun 8, 2018 | 08:33 PM
Maybe my shade tree method will work up there.
V12 HE Throttle Position Sensor Replacement.pdf
Adjusting the ECU fuel pot.pdf
TPS wiring my XJ.doc
As Doug etc has said, any TPS will work, as long as it has 90deg rotation in the correct direction, Some Mazda, GM, Ford have been mentioned.
Ya gotta get waaaaay outside the box with the thinking. Its a SIMPLE car, and thats fact.
