source for hand brake micro switch?
Old Aug 24, 2016 | 03:23 PM
gkazimir's Avatar
Default source for hand brake micro switch?
So, thanks to all of the posters, it IS indeed the micro-switch in the hand brake. At least, we're 99% sure of it.
Now...what's the best source for one? If anyone has replaced it and has info, it would make the hunt much easier I know. TIA!
Old Aug 24, 2016 | 11:49 PM
Jagboi64's Avatar
A quick google of the part number brings this up:
https://www.britishparts.co.uk/produ...dbrake-DAC3351
Apparently this one also works: Low Cost Standard Microswitch with Roller | Maplin
Old Aug 25, 2016 | 10:13 AM
gkazimir's Avatar
Thanks. The Maplin switch is only available to those in Ireland or the UK. I've sent a note to the other company - theirs is significantly more expensive, but may be the only one available :-(.
Old Aug 25, 2016 | 11:35 AM
BC XJS's Avatar
That's a common microswitch. They are used in dental equipment as well of countless other applications. I've picked them up at local electronics stores here in Canada.
Old Aug 26, 2016 | 08:51 AM
gkazimir's Avatar
That's good to know! I think I may have found one here, also:
Welsh Enterprises
800-875-5247 EXT 165
740-282-8649 ext. 165
740-282-1913 fax
Old Apr 21, 2018 | 07:53 PM
Cameronb's Avatar
i'm looking for this switch too, but i suspect the DAC3351 is for the coupe. my convertible has a parking brake interlock for the droptop and there are three leads. this switch only has 2 spades on it. if anyone knows the part number for the switch with 3 spades, i'd be much obliged.
Old Apr 21, 2018 | 10:50 PM
Time-Pilot's Avatar
I just bought one two weeks ago from Coventry West.
Coventry West - Jaguar and Land Rover Parts
Wasn't expensive, but I forget exactly what I paid since I bundled it with a few other things. It was used, but it worked great.
Old Apr 22, 2018 | 02:33 AM
Greg in France's Avatar
Correct. That Britpart switch is not the right one for any model. I bought one and found out the hard way. I told them but they did not believe me!
As you said, you need a three terminal microswitch which are NLA in the UK at least from Jaguar and the specialists. I ended up buying a pack of these:
https://www.amazon.fr/dp/B00E0JOTV8/...hvnetw=g&hvqmt=
Old Apr 22, 2018 | 09:50 AM
gkazimir's Avatar
The one from Welsh DID work btw....
Old Apr 22, 2018 | 10:57 AM
Cameronb's Avatar
i ended up ordering this. it's a 16 amp switch like the DAC3351, but it's a Single Pole Double Throw. I expect to have to bend the actuator.
https://www.aliexpress.com/item/5pcs...ceBeautifyAB=0
Old Apr 22, 2018 | 10:59 AM
Cameronb's Avatar
i couldn't find the switch on their site. i'm curious as to the Jag part number for the one you bought.
Old Apr 22, 2018 | 01:14 PM
I think this will not do it, certainly will not on pre-facelifts. You need three terminals.
Old Apr 22, 2018 | 05:56 PM
Cameronb's Avatar
there are three terminals on it, the ground terminal is on the bottom edge.
Old Apr 22, 2018 | 11:51 PM
Jagboi64's Avatar
I think this one might work too: https://www.digikey.ca/product-detai...1C5-ND/2754900
Or this one: https://www.digikey.ca/product-detai...378-ND/1824838
There are lots to choose from.
XJsc-guy
Jun 25, 2016 11:22 AM
GeorgioTsukolius
Jun 13, 2016 04:17 PM
agd
Jun 4, 2016 09:18 PM
Mad_Russian
XJ40 ( XJ81 )
Jun 3, 2016 10:49 AM
Jose
May 31, 2016 09:23 PM
