Spare tire retention nut? Which one do I need?
Old Jul 24, 2025 | 04:54 AM
monkfe's Avatar
Default Spare tire retention nut? Which one do I need?
Here is a picture of my spare tire / threaded rod that holds the spare tire in my 94 xjs. I'm trying to find out what is the correct nut/retention device to hole this in place. I have the offset one that holds it via the lug nut, but that particular rod doesn't fit into the earlier models that I have (made in Mar/93). So I'm on the hunt for whatever is needed here.
Old Jul 24, 2025 | 02:01 PM
equiprx's Avatar
Can you measure the threads of the rod and the ID of the wheel opening?
I might be able to match that up with stuff I have.
Steve
Pacifica CA
Old Jul 24, 2025 | 03:15 PM
motorcarman's Avatar
Regular wheel and SPACE SAVER WHEEL. are different.
CBC5627 CLAMP NUT shows to go through a wheel stud hole and clamp wheel in place.
Old Jul 24, 2025 | 03:36 PM
equiprx's Avatar
Same question, I might have the solution.
Old Jul 24, 2025 | 03:52 PM
monkfe's Avatar
Steve
Pacifica CA
1/2-13tpi, the hub of the wheel is 2.00 inches. I have the clamp nut used in the later models, but it's too small. I also have a handwheel....also too small diameter. Thanks for the help guys.
edit- full size spare...I'm beginning to think the xj-6 type might be the correct one. I'll try and find a pic.
Old Jul 24, 2025 | 04:42 PM
RGK20m3's Avatar
For a full size spare as pictured, the stud goes through one of the lug holes. Then a cylindrical spacer, and a black plastic thumb wheel nut that is about 2” inches diameter.
Old Jul 24, 2025 | 04:51 PM
monkfe's Avatar
well, the rod is straight(as pictured), and it doesn't line up with the lug holes like the later version does (they have the bend in it). Do you have a picture of this setup?
Old Jul 31, 2025 | 05:21 AM
monkfe's Avatar
So I finally got this sorted. I had to remove the rear steel panel and remove the existing carriage bolt and replaced it with the correct retention rod and nut. All is good now. Pic of the area where the rod attaches to the structure.
Stuart S
Jan 9, 2024 07:17 PM
debbie9744
General Tech Help
Jun 9, 2015 07:26 AM
brgjag
Jun 24, 2014 09:17 PM
ukester
Mar 12, 2014 06:11 PM
SirJag
Mar 5, 2011 05:19 PM
