Spark Plug Removal
Old Jan 5, 2012 | 07:58 PM
mrtalkradio's Avatar
Default Spark Plug Removal
I attempted the plug removal process today. It wasn't bad at all. These plugs are the original plugs. 71k on them, as you can see they are shot. The cap and rotor are original as well. I lightly sanded the rotor and contacts in the cap, lets see how it goes. The front 2 plugs were challenging. I took 4b out first it was the easiest and the white extension part of the plug broke off, I was like, I'm stopping now because I do not want to break a plug in those heads. First thing, Jaguar did use anti seize on these plugs when they were originally installed, and its proof the anti seize works. They all broke their seal very easily. So what I did on 1A and 2A was use a long extension and a hammer and tapped the extended part of the plug off. Mine were brittle and old, I don't suggest you doing it, but then again its my car. The pieces broke off like a piece of candy. I was then able to put a normal size 5/8s socket on the plug and a universal and out they came. The original spark plug wrench was just what the doctor ordered.
Attached Thumbnails Spark Plug Removal-marelli.jpg   Spark Plug Removal-marelli-2.jpg   Spark Plug Removal-marelli-rotor.jpg   Spark Plug Removal-plugs.jpg   Spark Plug Removal-broken-plugs.jpg
Old Jan 5, 2012 | 09:19 PM
JameyXJ6's Avatar
I would suggest you replace the cap and rotor as long as you have it off. Those Marelli rotors are notorious for failure.
When you put the plugs back in, I believe they are supposed to be torqued to 8 lbs, which isn't much, so be careful not to over tighten them.
A new set of wires, plugs, cap and rotor just might be all she needed if they're all original!
Old Jan 5, 2012 | 10:14 PM
Flint Ironstag's Avatar
I've had the dreaded Marelli rotor failure on both my 89.5 XJSs. This time I followed Kirby's advice and did the window sealant treatment. The cap looked fine, but I replaced it anyway while I was in there. The aftermarket cap is awfully light compared to the Marelli original.
Old Jan 6, 2012 | 06:28 PM
1a and 2b, whoaa...to put back in is like a brain teaser...still trying to do it.
Old Jan 6, 2012 | 07:27 PM
Doug's Avatar
Have you lifted the compressor?
Old Jan 6, 2012 | 07:44 PM
JameyXJ6's Avatar
I completely removed my A/C (mine is a convertible, seemed pointless) and now I can change the plugs in a total of about 10 min.
Old Jan 6, 2012 | 10:13 PM
robinlarry's Avatar
When I replaced my plugs last month, I indexed each one. Worth the effort I think. It ensures each plug is firing towards the combustion chamber...which would not have been the case otherwise.
Old Jan 7, 2012 | 04:51 AM
JameyXJ6's Avatar
I don't mean to sound ignorant...but you indexed each one? I have no idea what that means...
Old Jan 8, 2012 | 11:01 AM
I did now. I took it off, I'm changing belts anyway.
cissdm
May 3, 2016 06:02 AM
Pristine97XK8Convertible
Sep 10, 2015 09:24 AM
mrplow58
Sep 9, 2015 11:27 AM
MrMellor
Sep 7, 2015 10:22 AM
Bowman
Sep 3, 2015 03:17 PM
