Spot what's wrong in this picture
Old Jun 10, 2021 | 10:39 AM
manual_xjs's Avatar
Default Spot what's wrong in this picture
1992 XJS 5.3.
Great view of the inboard brakes.
How would you react if you discovered this?
Old Jun 10, 2021 | 10:56 AM
equiprx's Avatar
Zip-idi-do da.
Fuel line?
Old Jun 10, 2021 | 11:07 AM
manual_xjs's Avatar
No it's not that.
Old Jun 10, 2021 | 11:22 AM
Jagboi64's Avatar
Those nuts are difficult to get on, you need a thin walled socket. I'd be a bit concerned and doing any canyon carving, that's for sure.
Old Jun 10, 2021 | 11:35 AM
manual_xjs's Avatar
Agreed. Trying to replace it ASAP.
Could this mean it was not torqued up enough and slipped off - or even worse, not re-fitted at all?
Old Jun 10, 2021 | 01:10 PM
Greg in France's Avatar
Remove those daft UJ covers, then the nut can be far more easily fitted. You should use metlocs, which are one-time use nuts, available from the Jaguar specialist suppliers
Old Jun 10, 2021 | 02:12 PM
ptjs1's Avatar
I think that somehow its come off or not been replaced after being there for some time. A quick glance at those threads and it seems that the outer threads have become oil and grease contaminated, whereas the inner threads have become rusted implying that the nut was once there.
I second the suggestion to dump the dust shields!
Good luck
Paul
Old Jun 10, 2021 | 02:27 PM
manual_xjs's Avatar
Good luck
Paul
Cheers Paul. Yes it was on there last year, the guy whose job it was to replace it seems to have omitted it.
Do you know where I can get the metlock nuts in the UK, and what size they are?
Cheers.
F
Old Jun 10, 2021 | 03:00 PM
ptjs1's Avatar
Try googling "Aerotight Nuts"
Companies such as RS Components or Westfield Fasteners are pretty good.
Paul
Old Jun 10, 2021 | 03:21 PM
ronbros's Avatar
seems like a poor backyard mechanic at work!
Old Jun 10, 2021 | 05:23 PM
Jagboi64's Avatar
Thread is 7/16-20 UNF
Old Jun 10, 2021 | 06:07 PM
manual_xjs's Avatar
Thanks! Good shout.
Old Jun 11, 2021 | 01:15 AM
David Manners, ask for Jack Weston, for the nuts
Old Jun 11, 2021 | 05:50 AM
manual_xjs's Avatar
Thank you
Old Jun 11, 2021 | 09:05 AM
Brewtech's Avatar
Missing bolt and added zip ties to a fuel line says a lot about this poor cat. There are surprises Im sure
Old Jun 11, 2021 | 05:15 PM
manual_xjs's Avatar
All the nuts are in place and tight now
Yes there have been other surprises including a differential rebuild. Also done!
Daim
Feb 27, 2026 11:23 AM
stran0020
May 14, 2020 08:50 PM
LaserSVT
Apr 28, 2019 12:50 PM
revski666
May 13, 2016 11:03 AM
differentchances36
Mar 20, 2015 03:20 PM
