Stub Axle questions
Old Apr 25, 2019 | 11:27 AM
JigJag's Avatar
Default Stub Axle questions
I'm going to have to replace my stub axles. I'm wondering if anyone knows what OEM steel was used or what common replacement axles ( from sponsor vendors for example ) are? I've called and don't get any specific info other than "They're from the U.K.!".
I've located chrome moly stub axles and would like to know if it's worth extra expense, which is not enormous, and the shipment / import fees to get these? Seems a more direct solution and more permanent than bearing savers.
Old Apr 25, 2019 | 01:22 PM
Greg in France's Avatar
New stub axles are available from David Manners, SNG Barratt, XKs Unlimited etc. Forget bearing savers, say I. Often on ebay too.
Jaguar Partno_CCC5136*_FRONT STUB AXLE XJ SER 2 & 3_David Manners Group*
https://xks.com/i-6920131-jaguar-stu...a-ccc5136.html
Greg
Old Apr 25, 2019 | 03:32 PM
warrjon's Avatar
Use Loctite 620 on the inner bearing to prevent it from spinning on the stub axle.
Old Apr 25, 2019 | 05:37 PM
JigJag's Avatar
i thought about just going this route but wasn’t sure that it would be sufficient. If so I’ve many options.
Old Apr 26, 2019 | 03:20 AM
warrjon's Avatar
A mate of mine used to build e-Type and XJS race cars he told me to use Loctite on the inner bearing.
Old Apr 26, 2019 | 04:43 AM
Yep, Loctite is the go.
Before that, on my MK7, I used a centre punch at 3 spaced distances around the inner bearing seat circumference of the stub, and that inner bearing was then a TIGHT fit, and the wheel wobble ceased. This was in 1968, and way before Forums and stuff, "ya kept em going as best you could between beers".
My S2 cars all had the punch treatment, but the XJS's got the Loctite.
Old Apr 29, 2019 | 03:26 PM
JigJag's Avatar
Default Nylock nut followup
One more question if you don't mind. I heard a rumor that I need to replace the rear nylock nut on the Stub axle. Is that the case? It's proving hard to locate in the US. I have part number C8737. Is this nut a 1/2" UNF?
Old Apr 29, 2019 | 04:19 PM
warrjon's Avatar
I replaced the nuts with the stub axle. I bought the nuts from my local bolt supplier when I lived in Sydney.
bazanaius
Dec 7, 2014 08:11 AM
FastKat
Oct 4, 2012 09:44 AM
FastKat
Sep 29, 2012 09:06 PM
Italianguy63
Feb 17, 2012 06:47 PM
Lin
Nov 4, 2011 05:35 AM
