Thanks to many. Purists don't look
Old Dec 13, 2013 | 09:13 AM
Peel86XJS's Avatar
Default Thanks to many. Purists don't look
Electric fan, GM alternator in air pump bracket, Air pump removal. It started with a leaking radiator and I decided to make the modifications along with replacing all the fuel lines, cooling hoses, thermostats and new plugs/wires.
Used the cooling fan from Jagzilla. Wired the alternator and did the engine to chassis ground per Grant Francis. Pulled the air pump with help from many on that thread. Several times throughout the project I would stop and search the forum. My father was a little jealous. He had to work on his 74' XJ12L when there wasn't the internet.
Now I'm pulling off the dash to exorcise the electrical mess and air control problems from the PO. Everywhere I have been fixing there has been someone there before me and I keep scratching my head and saying, why?
Attached Thumbnails Thanks to many. Purists don't look-img_20131211_211928.jpg
Old Dec 13, 2013 | 09:46 AM
JagZilla's Avatar
Looks good. That fan should be more than enough for you up in Ohio, because mine has always kept things plenty cool for me down here during the long, hot, Mississippi Summers.
Old Dec 13, 2013 | 10:08 AM
Doug's Avatar
Botched repairs can be a real mess to figure out and correct.
Beyond that.....
I work on many cars that have been treated to some nicely done wiring repairs and/or modifications but have a devil of a time figuring out what exactly was done and the rationale behind it.
I've often had a silly dream about how nice it would be if everyone would leave a note behind......
"I rewired the truncator circuit by bypassing the turbo encabsulator relay. This allows to truncator to work whenever the key is 'on'. The blue wires are abandoned. Follow the yellow wires"
Old Dec 13, 2013 | 10:57 AM
JTsmks's Avatar
My DPO "hot wired" my fog lights direct with no relay or fuse, got what I thought was steam coming out of the hood seam on the way to work one morning and I figured I was overheating, gauge looked fine so I pulled over, popped the bonnet and looked to see a bald scorched wire had "burnt/sliced" it's way up through the loom, the only thing that stopped it was the bulkhead plug/connector. AAAHHHH, gott'a love DPO's (damn previous owners)
Old Dec 13, 2013 | 02:20 PM
warrjon's Avatar
Good job. Once you sort all the problems she will be a GREAT car, keep up the good work
Old Dec 13, 2013 | 04:51 PM
Sarc's Avatar
Don't worry about the purists...... the mods look sound and I'm sure make the car better.
Good luck with the dash removal..... thats fun
Old Dec 13, 2013 | 06:14 PM
warrjon's Avatar
No more red cordial for you. LOL
Old Dec 14, 2013 | 01:56 AM
Greg in France's Avatar
The OEM connectors in the dash loom are pretty good. The most important thing, I found when I had my dash off, is to separate each one and clean it very carefully with aerosol electrical connector cleaner and scrub the contacts with the cleaner using a "brass toothbrush" or similar implement. Secondly all the earths need rubbing down to bare metal (body and loom connector) and reconnecting and then protecting with grease or similar.
There are earths on the body vertical strengtheners each side of the aircon unit, on the tunnel LHS and various other places I have no doubt forgotten. Also, it is worth undoing the battery live feed posts (they go through the firewall each side of the aircon unit to supply power to the cabin and the engine bay) and cleaning them up and their associated connectors.
Also you will find there are rubber grommets for the aircon drains and the speedo signal which can easily be replaced once the tunnel and dash are out. If, like me, you are a nutter for these things, you can run a couple of extra wires from the engine bay into the cabin at the same time (just to have them there in case you decide you need them later). For example, I have a warning light for when my main fan is on*, plus a manual main fan switch if I want to switch on the main rad fan (or the thermostatic switch fails).
* boast alert Because my home designed fan chassis is so well rubber-damped it is impossible to tell if the fan is running or not from inside the car!
Greg
Old Dec 18, 2013 | 05:37 PM
dickc's Avatar
I changed out the ignition switches recently, that was all I wanted!
Dagny
Jun 11, 2024 01:06 PM
Jandreu
Jun 30, 2022 03:10 PM
perfectson
Nov 1, 2015 10:46 AM
Richard_gib
Sep 12, 2015 07:08 PM
dcvickers
Sep 2, 2015 06:14 PM
