Thread for spring pan bolts
Old Oct 2, 2016 | 08:40 AM
Daim's Avatar
Default Thread for spring pan bolts
Hey,
I'm getting frustrated with my springs and spring pans. Living in a purely metric country, you can't simply go to the nearest hardware shop and get some imperial sized threaded rods...
So I need to order them. As far as I have found out, the screws are normally 0.375". But what thread is on them? BSW? Fine? Corse?
Dammit, all I need is 4x 250m long rods but I have to place a SPECIAL order here for that...
Cheers people!
Damien
Old Oct 2, 2016 | 08:54 AM
Greg in France's Avatar
Daim
The thread is UNF. You can buy UNF threaded rod all over UK Ebay. A good idea to have some in stock. Or/also buy a UNF and UNC tap and die set, very useful, cheap, and has got me out of fixes countless times. Well worth cleaning up the threads with a tap in the bottom wishbone before reassembly too. Sometimes, even so, the bolts refuse to start and having a tap to do them with the pan in situ is also a great wheeze.
Greg
Old Oct 2, 2016 | 09:05 AM
Daim's Avatar
Cheers Greg!
Yeah, I'll get some as a spare part in case...
€19.90/910 mm... A standard M10 rod costs less than €2/1000 mm
Old Oct 2, 2016 | 09:28 AM
They saw you coming Daim:
UNF Threaded Bar Rod Studding Allthread
Greg
Old Oct 2, 2016 | 09:41 AM
Steve M's Avatar
Originally Posted by Daim
Hey,
Cheers people!
Damien
I don't think that you will need 250m long rods as there will be a little bit left over!
Old Oct 2, 2016 | 10:04 AM
Daim's Avatar
Oh, that would be a tad too long I actually meant 250 mm
Old Oct 2, 2016 | 10:33 AM
Jagboi64's Avatar
If it makes you feel any better, I removed the springs from an X300 last night and had to special order metric threaded rod. I could have bought inch sized rod off the shelf, there was lots in stock!
Old Oct 2, 2016 | 10:41 AM
Daim's Avatar
We could have swapped
They cost next to nothing here...
Old Oct 2, 2016 | 11:05 AM
Jagboi64's Avatar
It was $10 Canadian for a 1m length.
JigJag
Jul 15, 2022 08:14 AM
SocalJag
Dec 3, 2018 10:01 AM
johnwus83
US Northeast
Sep 23, 2016 03:47 PM
johnwus83
Sep 23, 2016 03:30 PM
jag_guy_2020
May 16, 2014 08:50 AM
