Tire Help
Old Mar 25, 2018 | 12:43 AM
skymark's Avatar
Default Tire Help
I have looked on line for a tire for my 1990 XJS and I can’t find anything but Pirrelli’s that fit the bill. I am trying to avoid a $1200 tire bill. Has anyone found a decent tire that fits the speed rating in the 235/60/15?
Old Mar 25, 2018 | 02:15 AM
Greg in France's Avatar
Over here anyway, there are none. If you can find some 16 inch rims, then there are loads.
Old Mar 25, 2018 | 02:59 AM
Steve M's Avatar
225/55 (I think, I'll check later) will do the job quite nicely; I've got those on the front because I couldn't afford the Pirelli ones (which are still on the back).
Slightly smaller tyres will make your speedo read a bit higher though.
Old Mar 25, 2018 | 09:09 AM
Doug's Avatar
I went to 225/60x15 to get more choices. That's was years ago; not sure what's out there now in that size. The pickins' are getting very slim on performance-oriented tires for 15" wheels
Old Mar 25, 2018 | 10:19 AM
sidescrollin's Avatar
I also used 225s because there is a much broader availability than 235s and a big difference in price.
If you don't plan on going 150 mph I doubt you will notice the difference in sidewall stiffness vs 130 rated
Old Mar 26, 2018 | 07:50 AM
Some Day, Some Day's Avatar
235/60? Not a chance. 225/60, there's a couple. Continental and Falken for a start. I've just put Continentals on the front, which means she's wearing Contis front and back now. Speed ratings are fine, too: W rating, good for 270 kph, which I regularly hit going to the local supermarket.
Old Mar 26, 2018 | 07:10 PM
Mkii250's Avatar
tirerack.com has a BFGoodrich and a Cooper in the right size
Old Mar 26, 2018 | 07:29 PM
Those have raised white letters on the sidewall, though. All right for an American muscle car, perhaps....
Old Mar 27, 2018 | 12:09 AM
Doug's Avatar
Just mount 'em blackwall out.
Never tried Coopers but the BFG offering is a good tire; in the 235/60 size it's the BFG rather ordinary standard issue "TA Radial"...not one of BFG's upper-line tires. I've had 2-3 sets over the years. Nothing remarkably good about them, nor anything particularly bad.
Dropping down a size or two isn't a bad idea in at least one respect: better fit on the wheel. The 235s are really a bit too wide for the 6.5" wide lattice wheels. No tire gives its best when it's pinched onto the wheel.
Old Mar 27, 2018 | 12:58 AM
Are they symmetrical? Some tyres have different tread patterns across the face. If so, it might not be ideal to just put black-side out.
But I agree with Doug--drop a size or two, say to 225. That's what I have on mine at the moment and they fit perfectly. Continental Premium Contact 2, which get pretty decent reviews: https://www.blackcircles.com/tyres/b...mium-contact-2
Old Mar 28, 2018 | 02:21 AM
user 652867429824's Avatar
try this place
https://www.discounttiredirect.com/?...ounttire%20com
Old Mar 29, 2018 | 04:12 PM
JigJag's Avatar
BFG Radial TAs are symmetrical and can be mounted RWL out or in. Just had a set mounted and love the look and performance.
Old Mar 29, 2018 | 05:02 PM
I would guess anything dated enough to have white text is going to be symmetrical lol.
Ive had falken ziex 912s for a while that I like a lot for the price. I think they dropped that design to another brand they bought, so now they are sold under "Ohtsu." Either way, decent tire for $80 or so. Also had them on a miata and they stuck well and have a good look.
Old Apr 7, 2018 | 07:15 PM
89 Jacobra's Avatar
Active Streak: 30 Days
Yes the BFG's Radial T/A's are symmetrical, and can be turned around black side out, they are not directional either. Hope it helps.
jack
DULLAH
27
Jan 25, 2019 04:12 PM
Rickfreeland66
Mar 4, 2018 05:14 AM
jlindy
Mar 20, 2012 08:53 AM
JagXK82001
Apr 7, 2011 01:32 PM
