Transmission dipstick tube
Old Sep 1, 2019 | 04:47 PM
bknorwood's Avatar
Default Transmission dipstick tube
All:
This picture is focused in on the transmission fluid level dipstick tube. It appears that this is supposed to be firmly attached at this point via a bolt & nut, but mine is missing the nut. Is that right? All I need to add is a nut & lockwasher?
Thanks,
Brad
Looks like I'm missing a nut & lockwasher?
Old Sep 1, 2019 | 05:14 PM
warrjon's Avatar
The dipstick tube is 2 pieces and this should be fixed or the dipstick could come apart.
Old Sep 2, 2019 | 01:16 AM
Greg in France's Avatar
Originally Posted by bknorwood
All:
Thanks,
Brad
I have just looked at this when removing my gearbox. That bracket attached to the lifting eye bolt should have a captive nut on the underside, then a 7/16ths socket on a wobble bar will undo the short bolt fixing the tube to it, allowing the top section of the tube to be lifted/wriggled out. It looks like your bracket has lost the captive nut. An ordinary nut and bolt will hold it fine, but getting it on will be a pain!
Dell Gailey
Jun 20, 2021 11:04 AM
The Coupe
Aug 4, 2020 07:22 AM
XJ6Paul
Aug 28, 2016 07:09 AM
Presence
Aug 28, 2015 06:48 PM
SD96XJ6L
Apr 7, 2015 05:23 PM
