Trunk Lid Gas Spring - winter and summer
Old Mar 17, 2018 | 10:54 AM
billmgeo's Avatar
Default Trunk Lid Gas Spring - winter and summer
I have another post today to do with the trunk lid.
I have a subjective observation that I would like to hear comments on.
My impression is that when the weather is cold, the gas springs that hold up my trunk don't have any pressure and as a result I have had the trunk lid hit me on the head - I also now keep a piece of wood in the trunk to prop it up if the gas springs don't appear to be holding properly.
They also appear to work fine in warmer weather.
Have others experienced this? Is it a function of the springs leaking or are they like that when new? I don't want to replace them if it is normal, but on the other hand, replacements are available if it would improve things.
Also I assume they are not serviceable or rechargeable?
I also assume that although Jag Heritage lists it by engine size 6 vs 12 cylinder is irrelevant as long as the VIN is appropriate.
I did search the forum for "gas spring" and nothing came up.
Regards
Bill, Canada
1992 XJS coupe
Old Mar 17, 2018 | 10:59 AM
Greg in France's Avatar
That is because the gas pressure in the spring is significantly lower in colder temperatures. A slightly below-spec spring shows this trait.
Old Mar 17, 2018 | 11:21 AM
orangeblossom's Avatar
Hi billmgo
I had the same problem on two of my XJS where on one the Bonnet/Hood would fall down
And on the other the Boot/Trunk lid would sometimes not stay up
Although I was intending to replace the Gas filled struts, as it gets pretty Windy round my way from time to time
I was always Paranoid about the Bonnet/Hood Lid falling down
Especially if there were some Tools laying on top of the Engine
Or I have left the Rad Cap on the Inlet manifold while topping up with Coolant
So in order to have piece of mind, I decided to use an idea put forward by Forum Member 'Jonathan W.'
Where you undo a Bonnet or Boot Strut and then slide a piece of Tubing over the whole thing
Having first made sure the piece of Tube is the same length as the piston
You could either use strong plastic but I went for Stainless Steel and it works great!
Thanks to Jonathan W. for this great Bonnet Strut idea which I also use on the Boot/Trunk of another XJS
Old Mar 17, 2018 | 11:58 AM
billmgeo's Avatar
Default Good suggestion of piping
Thanks Orange Blossom: really good idea and I think some solid plastic piping would be fine for the trunk....
Old Mar 17, 2018 | 12:52 PM
Jagsandmgs's Avatar
Had the same problem in cold snowy NH, but new ones did the trick. Rockauto is usually cheapest.
The cold weather thing I find odd is how stiff the heater temperature knob is when it’s cold out! As the car warms up it loosens up.
Old Mar 24, 2018 | 11:40 AM
billmgeo's Avatar
Ordered from Rockauto. Thanks for the recommendation.
Bill
xjrjag
May 25, 2016 04:33 PM
jaguarxjl
Dec 1, 2015 11:57 AM
SteveSheldon
UK & Eire
371
Oct 28, 2015 08:03 AM
ahunt4
Feb 3, 2015 10:50 AM
jaguny
Nov 12, 2014 05:57 AM
