trunk lock
Old Feb 3, 2014 | 12:20 AM
jagernut's Avatar
Default trunk lock
anyone have any ideas on how to get into trunk on a 1984 xjs i have no key and was told no access through back seat.can you get though from licence plate mounting hole??
Old Feb 3, 2014 | 11:03 AM
RagJag's Avatar
About a year and a half ago I got locked out of my trunk and front due to a malfunctioning lock module. After getting access to the trunk I disconnected the lock module. The key will lock and unlock the trunk but I don't bother doing so. Few people are familiar with the XJS trunk lid latch and I don't put valuable things in the trunk anyway. I was charged $50 by Pop-a-Lock to get into the car. That won't happen again. I seldom even lock it but do have a hidden ignition cut-off switch. There are only 4 or 5 XJS in my city. Steal one and you wouldn't be hard to find. lol
Cheers, RagJag
Old Feb 3, 2014 | 12:48 PM
rgp's Avatar
rgp
I had the same thing except the link had pulled off the handle, I drilled a
in the centre under the licence plate and it was easy but I cant remember
what made it easy, it wasn't hard once I could grab the rod. ignore the black area the hole in in the middle
Old Feb 3, 2014 | 09:30 PM
superchargedtr6's Avatar
The hole near the center will do the trick. My car has a 1/2" hole drilled a little right of center of the tag mount, and it is perfect for sticking in a screwdriver, and prying up on the release mechanism.
Old Feb 3, 2014 | 09:31 PM
jagernut's Avatar
ok great,thanks for info.one question.,so if i drill hole exactly in middle behind license plate i will see acuator rod from lock cylinder? does it run vertical or horizontal?is 1/4 " hole big enough?
Old Feb 3, 2014 | 09:44 PM
jagernut's Avatar
so if i drill a hole aprox 1/2" in diam.to the right of the top left tag mount hole i will see the rod that runs from lock cylinder to latch? so it runs vertically from lock cyln how do i detach it from lock or do i have to?
Old Feb 3, 2014 | 10:22 PM
jagernut's Avatar
superchargedtr6 by any chance you can send me pic of your hole in relations to area of trunk?
Old Feb 4, 2014 | 02:25 AM
rgp's Avatar
rgp
I only had a 1/4 hole but I cant remember (wasn't memorable) so must have been easy. what I put in it, but a grommet to finish
Old Feb 4, 2014 | 09:18 AM
I would be more than happy to send you a pic, its just that I'm not sure how. Can you direct me? I took a pic with my phone, but not sure how I get it on here. The actuator rod from the handle to the trunk release mechanism is defininately verticle, and can be seen clearly when looking at the hole in my trunk lid. The pic doesn't show that, a the flash of the camera distorts looking in the hole.
Old May 30, 2014 | 08:44 AM
NtAFord's Avatar
Anyone have any leads as to where I can find a complete replacement lock cylinder set up for an 89 XJS? This SNG Barratt group doesn't have it even though they claim they do. Looked on E-Bay and found a set out of a 95, wasn't sure if I could use those or not.
Old May 30, 2014 | 02:16 PM
Steve M's Avatar
Have I stumbled upon an elephant **** site?
magmedia
Aug 15, 2019 08:54 PM
XJsc-guy
Nov 23, 2015 01:56 PM
emilime75
XJ XJ12 ( X305 )
Oct 19, 2015 09:55 PM
Poet
Oct 2, 2015 09:00 AM
kevinl
Sep 24, 2015 08:25 PM
