Turning off security flasher
Old May 20, 2020 | 10:00 PM
prostreet124's Avatar
Default Turning off security flasher
I need to disable the security flashers, they flash non stop whenever I park car and will drain battery enough so it doesn’t start. Don’t know how else to turn them off, 91 XJS V12.
Old May 20, 2020 | 10:18 PM
VancouverXJ6's Avatar
It should not drain battery. I used to work away for 4+ weeks at a time and my car would fire up in the dead of winter no issue.
You probably have another drain on the system...disconnect radio then retest.
Old May 21, 2020 | 02:49 PM
equiprx's Avatar
Are you asking about the emergency flashers or the LED on the cigar lighter bezel?
The LED should never cause a drained battery,
Emergency flashers will definitely kill it.
Old May 22, 2020 | 11:34 AM
The little icon on dash and all the blinkers flash about every 5 seconds when ignition is off, very little flash but besides draining battery it’s annoying.
Old May 22, 2020 | 11:52 AM
Open up the radio and snip the wire? Or maybe see if its unpluggable.
Old May 22, 2020 | 06:23 PM
malc4d's Avatar
What does the radio have to do with the indicators blinking ?? sounds like an alarm module problem or key fob..
Old May 22, 2020 | 06:26 PM
I thought he ment the red security blinker on the radio, if its not that then I dont know, only ever heard bad stories about jag security systems.
Old May 23, 2020 | 08:12 AM
malc4d's Avatar
Sorry my bad...you are correct. sounds like he means the red LED on the radio and the red alarm LED. I have a 91 facelift and l cant leave it for anything like 2 weeks without a battery tender.
Old May 23, 2020 | 12:33 PM
MHF25's Avatar
When you turn off the motor,and exit the car - do you use the fob (check the battery) to lock the car? If so, the blinking lights are a sign that the security system is armed. If they continue blinking, then it is one of the fuses connected with the security system. Check the 3 fuses in the trunk. Right side panel. Check the fuse box under the passenger side dashboard. Your radio, antenna, door module controller, cigar lighter are NOT the cause. The issue is the security system. I have a 93 XJS. Went through 4 batteries. Removed the entire security system. Good luck. I'll check back. .
Old May 23, 2020 | 04:03 PM
macdoesit's Avatar
Banned
turned mine off with fob 3 years ago, ran my battery down too, no more battery problem
Johnde
Dec 13, 2016 06:08 PM
gotmoss89
Oct 19, 2015 09:44 AM
mannymux
Mar 26, 2015 08:04 PM
awmotors
XJ40 ( XJ81 )
46
Mar 18, 2010 10:43 AM
