I’m going to be replacing my carpet soon. While I have the carpet out, should I put in some sort of sound deadening/insulation or is the 35 year old whatever good enough? if I should, is any one product better than the others?
The existing insulation is both for sound-deadening but also uses foam blocks to fill the gap to the floor extrusion to enable the carpet to sit flat. However it can trap water.
If I were changing mine, I would fit some Dynamat foil for sound-deadening and heat insulation and then some closed-cell foam blocks to line the floor gaps then run some thin closed cell foam on the top before the carpet mats.
And before you follow Paul's sage advice, coat the fully dried out floorpan with PoR 15 or RustBullet. The floors rot from the inside out at least a much as from the bottom up. These modern coatings are 100% waterproof if two coats are applied as instructed. Under the back seat is also an area where the car can rust, so worth doing there too.
Do either of you know the approximate area of the floors? How much Dynamat am I going to need?
The front and back will be about 3 square metres. But my experience is that the boot floor and the skin of the rear wing outboard of the exhaust tunnels is worth doing too. When I have a full boot the sound definitely decreases noticeably.
I forget to add earlier: spray some wax, preferably preceded by Aquasteel, under the rear seat metal (shown in my pic above). there is a hole or two already there. This protects the rear radius arm and jacking point floor metal (which is under the seat bucket floor) from rusting from the inside out, too.
