V12 engine animation
Old Mar 21, 2017 | 08:50 PM
JigJag's Avatar
Default V12 engine animation
I made this when I was working on my distributor and timing and trying get get a better idea of the engine. I thought someone might find it interesting or useful.
I tried to accurately portray the intake valve duration ( but not lift ) with the arrows. The crank seems wrong to me somehow, but piston position and relative movement is correct.
V12 firing animation
Old Mar 21, 2017 | 09:55 PM
Addicted2boost's Avatar
Nicely done. I could watch that for an hour. Could maybe use a slightly faster movement.
Old Mar 22, 2017 | 01:43 AM
Daim's Avatar
Erm, I like it but something doesn't quite work... The crank seems to have too many throws... Shoukdn't it only be 6? And that 2 cylinders of the same number shape the same throw?
Old Mar 22, 2017 | 02:27 AM
Greg in France's Avatar
Brilliant, thanks for all the effort you took. It is in my favourites now!
Greg
Old Mar 22, 2017 | 02:28 AM
Daim, it is a DIAGRAM, not a technical drawing. WE all know the crank throws are siamesed, that is not the point, old chap!
Greg
Old Mar 22, 2017 | 02:37 AM
Daim's Avatar
Old Mar 22, 2017 | 02:56 AM
user 652867429824's Avatar
Love it, nicely done. Thanks for sharing and you hardwork on this, wish I had that talent. mind if I copy it to my files and share it with my sons?
Old Mar 22, 2017 | 06:14 AM
JigJag's Avatar
Greg
Daim raises a great point though. The crank is a mystery to me. I've seen it. I know it's 6 Siamesed pairs. I just can't model that as a flat 12. I assume it all works out in a 60 degree vee.
Creative Commons Attribution-NonCommercial-ShareAlike liscense. Print it and spray paint a moustache on it if you like.
can anyone tell me how the intake valves opening before TDC on the exhaust stroke works? I know lift is tiny at this point, but it seems counterintuitive. Same for staying open past BDC. Air mass inertia, magic, I don't get the 5000 rpm physics at all.
Old Mar 22, 2017 | 06:17 AM
Daim's Avatar
Would it work with a angled front view? Say if you looked at the front left corner and could see the rear cylinders and the front at the same side... Maybe would be an easier way to demonstrate?
Old Mar 22, 2017 | 06:38 AM
JigJag's Avatar
if I'd modeled this is 3D, yes. Best I could do in this 2D is to snug the rods up together properly, animate the crank correctly and just clip the rods where they disagree with the crank animation. Still wrong, but would look better.
3D animated V12 would be awesome. But I have alternator issues to deal with.
Old Mar 22, 2017 | 08:38 AM
The exhaust valve opens BEFORE BDC of the firing stroke, using residual combustion pressure to start the exhaust gases moving out, then as the cylinder rises on the exhaust stroke, it forces the gases out even more strongly.
The induction stroke on its own does not give enough time for the cylinder to fill efficiently with air/fuel mixture; BUT if the intake valve is opened about (say) 18 degrees before TDC on the exhaust stroke, the exiting exhaust gases "pull" the intake mixture into the cylinder, and magically the two do not mix to any significant degree. Essentially the exiting exhaust gases, having momentum AND having a pressure wave, keep roaring out of the exhaust port, and by doing so help to create a partial vacuum in the cylinder which helps draw the incoming fuel/air. And this partial vacuum and pressure wave is so powerful that it overcomes the fact that the piston is still rising.
Greg
