V12 Ignition???
Old Oct 18, 2018 | 07:32 PM
89 Jacobra's Avatar
Active Streak: 30 Days
Default V12 Ignition???
Did the Jag V12 HE, ever have a regular point style distributor? Or one that could be used / retrofitted? Is there any kind of upgrade, such as an ignition box similar to an MSD, with a pickup coil inside the distributor, and OR ???? I'm considering taking the Extra XJS I have, and creating something unique. Unfortunately I need a stand alone Ignition, and fuel system. I will probably have to build a three manifold setup, to set a Ford 2 barrel Carburetor, over each set of 4 cyilnders, AKA "3 Dueces", as I don't want to mess with fuel injection. Since my wiring harness won't be there. As It's going to be used for the Jacobra. Any Thoughts, or ideas will be appreciated. I may just give my old XJS, Rust bucket "parts car" a new life? This could get interesting.
Jack
Old Oct 18, 2018 | 08:20 PM
Doug's Avatar
No points-type ignition ever used on the HE V12. In fact, I think every V12, right back to 1971, had some type of solid-state, point-less ignition.
I'm pretty sure that Crane and Pertronix make V12 ignition kits
Old Oct 18, 2018 | 08:44 PM
89 Jacobra's Avatar
I'll have to check it out. Thanks Doug
Old Oct 18, 2018 | 09:07 PM
superchargedtr6's Avatar
I have the Crane system on my 71 V12. Works great. I use the Crane full 12 volt coil as well. Had to bypass the factory ballast resistor
Old Oct 18, 2018 | 11:03 PM
VancouverXJ6's Avatar
There was another company Omex I spoke with awhile ago, they have built drop-in engine/ignition management units before for V12s apparently.
I never got back to him but they would just need a complete list of sensor inputs and maybe some diagrams and other relevant details to ensure its all good. I got the impressiom its not hard to use this product with a coil on plug setup, or you can retain the dizzy etc.
Jaguar2986
Mar 9, 2017 02:47 PM
his196
Sep 25, 2014 02:52 PM
MLRocafella85
Jun 18, 2011 02:19 PM
WillieE
May 17, 2011 11:14 AM
