v12 tdc timing marks
Old May 18, 2017 | 02:49 PM
275nart's Avatar
Default v12 tdc timing marks
For whatever reason this motor I have is missing the timing marks. Shouldn't there be a little plate there right below the pulley that mounts off of two of the front oil pan bolts? Does a repro exist for this plate? I can't for the life of me find one for sale online... Thanks for any help!
'85 v12
Old May 19, 2017 | 02:12 PM
275nart's Avatar
SNG Barratt - The Ultimate Jaguar Parts Specialist
found the part called a "timing indicator" #C37355 , cheap part, but seems to be special order or out of stock on this side of the pond.
Old May 19, 2017 | 04:40 PM
JigJag's Avatar
I believe 0 is dead center bottom. I'll check. You could fab your own.
Old May 19, 2017 | 07:01 PM
BradsCat's Avatar
there are a couple of junkyard cars near me. I could see about pulling one for you.
Old May 19, 2017 | 07:25 PM
275nart's Avatar
Thanks for the offer! How 'bout a pair of intake manifolds? I was able to order it through SNG and the rep said it should only take a week or so to get. It's a cheap part and don't mind paying for a new one.
Old May 19, 2017 | 08:38 PM
BradsCat's Avatar
Yep, I can get those too. Let me know. I'm in central VA if you want to drive up and get them yourself. I can steer you to the junk yard.
Old May 20, 2017 | 09:51 AM
Greg in France's Avatar
0 is, I believe, TDC on A1 piston.
Old May 21, 2017 | 09:25 PM
mikebaker3's Avatar
Is your car an 89 or newer with Marelli Ignition?
The Marelli cars have a small indicator where the crank sensor mounts and does not have the scale that the Lucas ignition cars have.
Old May 21, 2017 | 11:19 PM
JigJag's Avatar
I was speaking of the location of the mark on the timing gauge under the crank. That gauge is oriented with 0 at the dead bottom of the pulley. I think. I haven't had a chance to look yet.
If I'm correct then you could, I don't know, glue a protractor on?
Old May 22, 2017 | 12:54 AM
Apologies for my misunderstanding. The actual timing marker scale is on slotted holes and is slightly adjustable. So to get it dead accurate it is best to ensure A1 is at TDC and then align the scale's 0 mark to the crank mark.
Old May 22, 2017 | 05:28 AM
JigJag's Avatar
That is the best method.
Some years have slotted, adjustable gauges. Mine is the style in the illustration above. These type are not slotted and can only be mounted in one position.
Old May 22, 2017 | 10:04 AM
275nart's Avatar
No it's an '85 motor with Lucas ignition.
I need it at tdc to pull the distributor and seal the upper valley cover. Thanks for the help fellas.
