Vacuum pipes
Old Nov 26, 2018 | 02:19 PM
brinny's Avatar
Default Vacuum pipes
Evening all. I have a question on the vacuum pipes that go to the end of the inlet manifold on the drivers side. There is a little cluster of 3or4 pipes and a blank. Does it matter which pipe goes to which or are they all supplied the same bar the one that is blanked. I know one is the trans vac pipe not sure on the others. Much obliged.
Old Nov 26, 2018 | 03:27 PM
Greg in France's Avatar
It does not matter. One is the gearbox modulator, one the aircon vac source, one the full throttle vac switch, forgotten if there is another or not!
Old Nov 26, 2018 | 03:44 PM
brinny's Avatar
Ha ha ha, cheers Greg.
Old Nov 26, 2018 | 04:43 PM
orangeblossom's Avatar
Isn't one of those Vacuum pipes for the EGR Valve that goes on the Cruise?
EGR Valve for the Cruise Control
Old Nov 27, 2018 | 01:52 AM
I have a feeling that gets vac from the other end of the manifold, OB (I have removed my cruise).
Old Nov 27, 2018 | 06:22 AM
Daim's Avatar
Absolutely right there Greg. The CC bellows get their vacume from the A bank front vacume connector.
Old Nov 27, 2018 | 06:24 AM
Daim's Avatar
OB, that is by the way not an EGR valve. EGR stands for Exhaust Gas Recirculation. A vacume is no recirculation. That is simply a vacume switch. And even that isn"t fitted to all XJ-S models. My 89 had a working CC and direct draw off the intake manifold. No little vacume switch at all in that area.
Old Nov 27, 2018 | 07:19 AM
Hi Daim
I should have said Vacuum Solenoid
Old Nov 27, 2018 | 07:55 AM
Doug's Avatar
I think that vacuum switch was originally part of a recall and subsequently incorporated into normal production for certain markets.
Old Nov 27, 2018 | 12:46 PM
brinny's Avatar
Many thanks all
Old Nov 28, 2018 | 03:50 AM
roman_mg's Avatar
Yes, it was incorporated after recall, there was cases, that CC could not be turned off (when was connected directly to vac) and this switch corrects it.
new mexico
Apr 29, 2017 02:28 PM
heflirob
Oct 21, 2015 06:39 PM
8bit
Aug 7, 2015 03:25 AM
aaronb
Jul 10, 2015 06:22 PM
