What did you do to or buy for your XJ-S/XJS today?
Old Apr 23, 2016 | 09:07 PM
  #361
NJ2003XJ8's Avatar
In my battle with oil leaks replaced valve cover gasket - easiest job ever on my engine!
What scared me the most is how easy it was to crack the old gasket, feels like if I dropped it on the floor it would shatter into pieces. Makes me think about all other old gaskets that are still there.
Here is the pic of the engine with cover off, lot of oil in there!
Attached Thumbnails What did you do to or buy for your XJ-S/XJS today?-20160423_201408.jpg
Old Apr 27, 2016 | 07:24 PM
  #362
chriskindbooks's Avatar
Checked oil in rear end, topped it up. Changed oil to 5/50 Castrol from 15 /50 Mobil and it ran so smooth. Love my XJS
Old Apr 28, 2016 | 05:36 AM
  #363
Steve M's Avatar
Getting new full flow oil cooler and pipes fitted today and tomorrow.
Old Apr 28, 2016 | 06:33 AM
  #364
Brake buster's Avatar
you should be able to make it to Kemble then ?
BB
Old Apr 28, 2016 | 07:57 AM
  #365
Steve M's Avatar
Fingers crossed, if the cooler arrives on time.
Justjags did a good job of getting a replacement when their manufacturer let them down.
Equally exciting, just unwrapped an oxblood leather, swivel and recline chair for the boat; £100 off Ebay including £35 courier, looks brand new.
That will go nicely with the existing oxblood Chesterfield and matching ottoman stool found in an antique shop.
It'll be a proper man-cave now; have to get a pipe to puff on whilst quaffing port and failing to do the Times crossword.
Old Apr 30, 2016 | 02:02 AM
  #366
Greg in France's Avatar
Default Aircon upgrade Delanaire Mk II
For all Delanaire Mark II cars (pre about 1987 I think). I removed the OEM aircon amplifier and replaced it with a new digital one (looks like a 12 bore shotgun cartridge, only white). This is now available new from David Manners, but used to be made by some people on Oz, who stopped for some reason. The difference is amazing, aircon much more responsive, better control, absolutely superb. Highly recommended.
Greg
Old Apr 30, 2016 | 06:41 AM
  #367
jal1234's Avatar
Do you have a part number or link for the aircon amplifier? Part of your post looks like a link, but doesn't work, and I can't find it on their website.
Old Apr 30, 2016 | 07:21 AM
  #368
This is the OEM part (2 in the diagram):
Part no. C45402 | Air conditioning amplifier parts from Jaguar Classic Parts UK
You take off the LHS footwell vent on the gearbox tunnel side, then undo the rearmost end of the relay (part 3 in the diagram) and this enables you to pull the amp from its clip under the main body of the aircon unit. The OEM unit's multiplug and earth wire are a direct swap for the new unit that looks like this:
I bought mine last year from Manners and have only just got around to fitting it. Part number is C45402, I cannot find it on their website either, but if you 'phone or email David Manners they will be able to tell you if they still have stock. I expect they do, but have just been pathetic about their website including it.
Just done an Ebay search, there is one only left in Oz, (priced in Aussie Dollars)
http://www.ebay.co.uk/itm/Jaguar-XJ6...oAAOSwdU1W-xNo
Greg
Old Apr 30, 2016 | 05:35 PM
  #369
Steve M's Avatar
Got it pushed into a lay-by the local Police force.
Then pushed into a Land Rover dealership.
Deeply depressed.
But don't worry, beer is getting me through it!
Old May 1, 2016 | 02:32 AM
  #370
Deeply depressed.
Steve
Whatever garage is meant to be looking after your car, I suggest you change it! Fuel smells in the boot after a tank job, and all this other grief you are getting, got to be the fault of the garage.
Greg
Old May 3, 2016 | 09:32 PM
  #371
Padre's Avatar
Bought it on Thursday, it was delivered today.
1994 Jaguar XJS 4.0 Coupe, 136,000 miles. Body is very straight, mechanically sound as well.
Then I parked it on the lawn for some pictures.
Now I'll begin a full series of maintenance checks.
Padre
Old May 4, 2016 | 10:30 AM
  #372
Steve M's Avatar
Nice!
Old May 4, 2016 | 10:48 AM
  #373
frenchfairplaydriver's Avatar
Default chromium and chromium
Hello everyone
this morning I changed the blade right rear bumper
there was a slight corosion
the other being perfect
the taste of Perfectionism
good evening to all
Old May 5, 2016 | 12:17 PM
  #374
Daim's Avatar
I removed the aircon today... Need to get that V colder and protect it from future heat problems. At the same time I removed a few parts for an upcoming project: making the Iron Lady keep her oil inside!
[img]https://c2.staticflickr.com/8/7025/26766851721_cd037aeb32_b.jpg[img]
The aircon parts will be wandering into my garage to store. I might sometime want to fit them again
Old May 5, 2016 | 02:10 PM
  #375
Beavis's Avatar
...and all I did was purchase a new alarm key fob...
Old May 6, 2016 | 08:59 AM
  #376
Jonathan-W's Avatar
please check this for holes ... I saw this kind of rust on mine and they were rusted through (underneath the rubber...) I fixed them... painted them...
great place for steam to weep out and reduce the amount of coolant with out a trace of dripping on the driveway! found my holes by prodigiously overfilling my system :-)
OH and
interior cover from covercraft...
New tires today or tomorrow...
along with
Merrilli distributor cap / rotor / magnacore wire set, 12 Denso IT20TT plugs, appointment to have all the injectors cleaned and matched...
Old May 7, 2016 | 12:10 PM
  #377
Daim's Avatar
Carried on removing parts to get to the front of the engine. Radiators are out and the bonnet removed. Makes life a lot easier. Whilst I am in that area, I'm redoing the water pump. The pipes show, that coolant has reacted with each other and caused the fluid to crystalize. So I need to flush the engine a bit...
Waterpump removal is a pig... Whoever thought it was good to place it in such a position and in that size!? The AJ-V8 only needs 5 bolts to hold the water pump in place... And access is easier!
The job is rather hard and awkward but to be honest, it is fun!
Old May 9, 2016 | 09:19 PM
  #378
JagZilla's Avatar
Over the weekend, my son and I replaced the crapped out old-style starter on SpeedDemon (my '88), with a spare gear reduction starter. We also replaced the rear shocks and springs while we were under the car.
The original starter crapped ouut on my son Wednesday night, forcing him to call me for help. After running diagnostics on the starter circuit, we determined that the starter was bad, and we had to call a tow truck to get the car home.
I bought the car for $1,800 on ebay, from a guy in Maine 8-1/2 years ago. In that time, either my son, or, I have driven the car 6-7 days per week, for a total of 150-200 miles per week--every week. This is the first time the car has ever stranded one of us. That's a great testimony for any 28 year old car, and it blows a huge hole in the myth that Jags are unreliable.
Old May 11, 2016 | 05:17 PM
  #379
Padre's Avatar
Inspired by the "Wheeler Dealers" XJS episode, I pulled out the transmission mount (gearbox mount) and cleaned it up. (Mine's a '94 4.0 automatic coupe.)
Here's the video, starting after the 5:00 mark:
My pre-purchase inspector had said the trans mount was "broken". Took it apart, and aside from being clogged with junk, the springs were in good shape (they're also like $30-$50 each, so I'm happy I didn't have to replace them). Only one of the rubber "spring seats" was bad. But I found a whole set on eBay and replaced all the rubber pieces.
Every little bit helps, pretty easy to do.
Padre
Old May 11, 2016 | 05:47 PM
  #380
BC XJS's Avatar
Nice job
