Wheel size
Old Sep 22, 2019 | 11:30 AM
rgp's Avatar
rgp
Default Wheel size
Will 5 x 108 et20 wheels fit an xjs.
Old Sep 22, 2019 | 11:52 AM
leo_denmark's Avatar
No, they are for much newer Jags.
XJ-S uses 5 x 120.65
Old Sep 22, 2019 | 12:11 PM
rgp's Avatar
rgp
Default What about these
Anyone got these wheels on there xjs
Anyone seen these type wheels on a xjs
Old Sep 22, 2019 | 10:32 PM
Rivguy's Avatar
They are called the "dimpled" alloy wheel. 16 inch. They were one of several choices on the 1995-97 X300 XJ6 models, My '97 has them. I would also like to have those wheels on my XJS. I haven't tried fitting them. Do they have the seem wheel lug pattern?
Old Sep 22, 2019 | 11:29 PM
They should fit, but they are not 5 x 108...
Old Sep 23, 2019 | 02:25 AM
rgp's Avatar
rgp
the advertiser of these isn't advertising any hole size but they are 8" wide x 16" and cheap for £50 for 2.
Old Sep 23, 2019 | 11:22 AM
Jagboi64's Avatar
The wheels in the photo should be 7" wide, not 8. As far as I know, the only wheels fitted to X300's that were 8" were the XJR wheels.
Old Sep 24, 2019 | 04:10 AM
rgp's Avatar
rgp
these dimpled wheels are in the jaguar accessory book 1996 but not listed for use on the xjs, they are available 7" and 8* with a 33 off set. I wonder why they wont fit or the problems of fitting them are, picture from a set on ebay showing size, I currently have RW macho 8" rears on the back with an offset of 22 they miss the outer wheel arch flange with 235-60-16 tyres fitted
this picture is of a dimple wheel on eBay currently
Old Sep 25, 2019 | 10:17 AM
Jagboi64's Avatar
Learn something every day. I had no idea that style was ever available in 8" width.
Old Sep 29, 2019 | 02:39 PM
fishbait1's Avatar
I have these on my 94 XJS. they were n it when I bought it. not my first choice however. I prefer the 5 spoke rims. the ones I have are 16" but not sure of the width and I assume they are a 33 offset.
is 33 offset the standard for the XJS wheel?
Old Sep 29, 2019 | 02:56 PM
Keesh's Avatar
32 offset is standard for a 7J rim and 25 offset for a 8J rim .
Old Sep 30, 2019 | 07:44 AM
rgp's Avatar
rgp
the one in the picture is 8" and as it states in the casting in my previous post 33 offset jaguar oe wheel so no good for the xjs?
Old Sep 30, 2019 | 11:28 AM
Keesh's Avatar
Maybe it fits, wheel come 7mm inwards
Old Sep 30, 2019 | 11:30 AM
Jagboi64's Avatar
33 is a very common Jag offset, it should fit an XJS just fine.
Old Sep 30, 2019 | 11:52 AM
Keesh's Avatar
Yes, for the 7J XJS rim, and the 7J and 8J for the XJ. Note that many people have used '94-97 XJR 17" X 8" wheels on an XJS, and these wheels have a 25mm offset, for a good reason.
Old Sep 30, 2019 | 11:46 PM
Rivguy's Avatar
Fishbait, You've got the wheels that I want for my XJS. My car has the lattice which look good but are only 15 inch. Hard to find good tires in 15 inch. But first I've got to get my car running right again!
Bunky Twincam
Jun 26, 2015 09:27 PM
Jonathan-W
Dec 29, 2014 05:53 PM
car5car
Jun 4, 2014 10:56 AM
fire_fighter00
Mar 31, 2012 05:03 PM
