wire loom
Old Feb 7, 2015 | 07:42 PM
mtpckts's Avatar
From: collinsville,Ill-18 miles from downtown ST,louis
Default wire loom
i have 89 XJS V-12 are there a maker of fuel injection harness. and other engine bay parts?
Old Feb 7, 2015 | 07:54 PM
superchargedtr6's Avatar
There are, but my experience is that you can do it yourself just as well for loads less. Several posts concerning this....
Old Feb 7, 2015 | 09:08 PM
Sarc's Avatar
But the connectors off eBay..... About $2 each. Remember to get 14 if you have cold start injectors.
High temp wire. A weekends work. Quite rewarding.
Old Feb 8, 2015 | 05:20 AM
Brake buster's Avatar
here is how i made my loom
https://www.jaguarforums.com/forum/x...ctures-127573/
just take your time and do lots of research
if your in a real pinch , i could make one for you
BB
Old Feb 8, 2015 | 05:39 AM
CoxynotKirsty's Avatar
I was wondering if someone could explain something to me, if the injectors are firing in banks of four, I assume that means that three fire off at the same time - what happens to the fuel for the two cylinders that don't have a spark.
I would be thankful if someone could post an image of where the wires are spliced together.
Old Feb 8, 2015 | 05:50 AM
it stays in the induction system for a fraction of a second until the next cylinder uses it,
this is a wasteful system compared to sequential injection , but was current technology at the time
so that one of the reasons we get low MPG from our wonderful V12's
BB
Old Feb 8, 2015 | 06:20 AM
Thanks for the reply, it's something that I have not seen explained before.
Further to the wire splicing, I had another look at Bernard's website and saw it was as simple as it sounds.
Coxy
Old Feb 8, 2015 | 09:46 AM
Out of curiosity, is your car a Marelli ignition car? Not a bad idea to build both the ignition, and the injection harnesses while at it.
I'm sure your car does not have cold start injectors. I think these went away in 1986?
Old Feb 8, 2015 | 11:25 AM
Greg in France's Avatar
BB
Actually BB, I bravely disagree. Sequential ignition, if I remember correctly from Roger Bywater's book, would make naff-all difference to the fuel consumption of the Jaguar V12. Essentially at, say, even as low as 2000 rpm, the timing of the injector pulse is, on our V12 engines, immaterial to consumption. The poor fuel consumption is a function of other factors: combustion chamber design, rotating mass, autobox, body weight, over-square cylinder/piston, etc etc.
Greg
Old Feb 8, 2015 | 12:13 PM
lol
better explanation than mine.....
i just did a quick google search , but i didn't read all the relevant info , lol
google , everyone can access it........just got to make sure you can understand what your being told, lol
BB ;-)
Poet
Feb 7, 2025 02:18 PM
jagent
Jun 5, 2022 02:18 PM
Rocky15
Sep 28, 2015 04:59 PM
andyw
Sep 26, 2015 01:59 PM
driver safz
Sep 26, 2015 06:01 AM
